Stock Platinum Plugs SUCK! What were they thinking with that little PUCK!
I replaced my plugs/wires today with NGK TR55/Taylors. All the plugs were done in a half hour except that #@$%^&^king :cuss :cuss :cuss :cuss :cuss #7 Plug. Had to go out and buy a universal swivel to get it out. Thank god for the low torque required for these Aluminum head plugs or I'd never get it out. And how about that friggen razor sharp wire harness clip right where your wrist is. Good design. Looked like I tried to commit suicide :D
Anyway, the last plug had the Damn Puck missing. (hopefully not wedged in my rings and scoring the friggin cylinder wall) Get these peices of $ H I T out of your engine. Crappy design. The Taylors are a dream to install! No guessing if they are on. A nice snap! Make sure to coat the insides with the supplied silicone grease. The rubber boot only! not on the contacts! Remember Dielectric .... Engine idles smooth as glass now! |
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (chuckster)
right on chuck. :cheers:
Im sure your puck got blasted out the exhaust port. :) I wonder what buffoon signed off on using those pucks on the electrode.... :crazy: |
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (kewlbrz)
chuckster, kewlbrz - not much of a mechanic so how about some heads up... http://www.corvetteforum.cc/zeroimg/...withstupid.gif :confused: :D
looking in the Ecklers catalog there are at least 4 sets of wires and plugs. wires 90 to 140, plugs 30 to 60. is there much difference for the price. what are your opinions?????? are the ThunderVolt 50 wires the best because of the 10.4mm size? what makes ngk better than ACDelco or bosch???? Thanks in advance. |
I was undecided on replacing the spark plugs, but now I'm undecided on which wires to get?
:cheers: [Modified by c5vetteman, 9:28 AM 11/25/2001] |
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (c5vetteman)
Chuck -You really got worked up over this swap. I got as pissed when I pulled my stockers out. I completely agree, the stock plugs are crap. About the #7, just remove anything that's in your way next time. That clip comes off the coil mount real easily. I can get the plug out with just a 3 in. wobble extension if I get all of the hazards out of the way.
ChaseN -Which plugs to get depends on what you want from them. Strictly performance...get all copper i.e. NGK TR55's. Longevity...get some platinum or Iridium tipped plugs. A plug wire upgrade decision is down to 2 options. The Magnacor are highly touted on this forum, they do have really good numbers. I have the ThunderVolt-50's. These wires were the only hand inspected units available to me. They have the least resistance of any wires as well. The quality of these wires is far better than either the standard Taylors or the MSD's imo. BTW, you'll get the best deal from one of the Forum Vendors. |
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (ChasNMe)
#7 is a tuff one, but its not so bad using the Snapon Swivel S9721, just take your time.
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (wallstAL)
Al,
How does the Snap On Swivel different from the ordinary universal swivel? I am dreading the next plug change and I was thinking about picking up Snap On if it's that much better than universal swivel. THanks |
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (sbkim)
Al, How does the Snap On Swivel different from the ordinary universal swivel? I am dreading the next plug change and I was thinking about picking up Snap On if it's that much better than universal swivel. THanks The difference in a normal swivel is that the socket is integrated to the swivel. Very slick. http://www.vetteguru.com/mods/igniti...s_wires_1b.jpg |
I bought that Snap-On swivel socket ($40!), and it IS a big help. Still not an easy job though. The Snap-On socket has 2 swivel locations, which helps it get around corners. You could try the same with a sparkplug socket & 2 universals, but the whole mess would start to get sort of long & cumbersome. Steve. |
I also changed my plugs and wires today when I installed my B&B headers. I was surprised to see my 01 had Danso plugs in it :cuss I put Bosch Plat 4's with GM Performance (red) wires. I am happy with the headers, plugs and wires :)
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (NastyC5)
I also changed my plugs and wires today when I installed my B&B headers. I was surprised to see my 01 had Danso plugs in it :cuss I put Bosch Plat 4's with GM Performance (red) wires. I am happy with the headers, plugs and wires :) [Modified by FRC Tom, 11:30 PM 11/24/2001] |
Re: Stock Platinum Plugs SUCK! What were they thinking with that little PUCK! (FRC Tom)
Just bought an 02, are they still installing these plugs? I remember them as problems in the C4's, would have thought that would be corrected by now :mad
With all the bad experiences people have been having with the stock plugs I decided to check mine (2000 with 8kmi). I pulled two plugs, one had the puck, one didn't :-(.
Now I just need to find a local supplier for the TR55's. Think I'll do a compression test to see if the cylinders with missing pucks are down on compression. I wonder if GM/Delco is aware of the crappy plugs. |
