Heads for 400 small block
Once a pair of heads has been drilled to allow proper water circulation on a 400 block, are they then only compatable with a 400 or could they still be used on a 350?
Re: Heads for 400 small block (A)
The holes that are drilled into a head to use on a 400 block are steam holes. Use the correct head gasket and they can still be used on a 350 engine. It will block the steam holes.
