Dry sump without losing A/C
Are there any choices out there? I would like to keep the A/C, but also have a good dry sump.
thanks |
Originally Posted by Wicked Weasel
(Post 1563215707)
thanks Anyway, I've looked into it a good bit and only found one system that allows you to keep AC: http://www.aviaid.com/pdfs/ls1and7_broch.pdf The "LS-A" setup is the only one that allows you to keep AC. -TJ |
Thanks
I will have to call them to see what pump they offer with it. This would probably be better than nothing, but not sure how affective. |
In a dry sump you typically do not vent any part of the motor so the oil pump can pull a vacuum.
Originally Posted by trackboss
(Post 1563219083)
-TJ |
With a dry sump you are trying to extract all oil from the engine as efficiently as possible so it is best to pull a vacuum. Any breathers on the engine will not help there. The tank is where everything vents. PCV (in stock location will not work.) All factory motor vents should be removed. I'm no expert, but if you are looking for emmissions compatability it would be a good idea to look at the ls7 setup. I'm sure they had to do something there to comply. Just an idea, but I would bet they vented the tank back into the motor intake tract somehow. Possibly similar to how the stock pcv is vented to the throttle body area. Just keep in mind that anything behind the throttle body blade is vacuum so if that is not desired vent before. You may be able to simply connect the vent at the tank to an inlet behind the throttle blade and put the pcv inline there just like stock. These are all just ideas. I haven't thought this out entirely.
(Post 1563222546)
My worry is that if the sump-pump doesn't pull enough vacuum my motor seems to create a lot of positive crankcase pressure (some blow-by I'm sure, though leak-down tests are very healthy on it). W/ the stock PCV setup it'd push out valve cover gaskets from time to time, and once my ghetto rigged PCV setup that's on it now kinked and it pushed out a valve cover gasket. I'd LOVE to get rid of all my PCV/catch-can/James Bond Smoke Screen woes. So Wicked Weasel you want to contact the manufacturer, get setup as a distributor, and run a GP for us!?!?! :D -TJ |
Originally Posted by tjZ06
(Post 1563223938)
I'm not worried about emissions... I have bigger issues there. Haha.
My worry is that if the sump-pump doesn't pull enough vacuum my motor seems to create a lot of positive crankcase pressure (some blow-by I'm sure, though leak-down tests are very healthy on it). W/ the stock PCV setup it'd push out valve cover gaskets from time to time, and once my ghetto rigged PCV setup that's on it now kinked and it pushed out a valve cover gasket. I'd LOVE to get rid of all my PCV/catch-can/James Bond Smoke Screen woes. So Wicked Weasel you want to contact the manufacturer, get setup as a distributor, and run a GP for us!?!?! :D -TJ And if someone wants to make us a distributor I am sure ECS would do a GP. |
(Post 1563224088)
I am talking to a few places right now to see if there are any options for A/C besides the 2 stage pump showed above (which would be an ok alternative). I will let you know what I figure out.
And if someone wants to make us a distributor I am sure ECS would do a GP. -TJ |
well after talking to a bunch of different companies that specialize in dry sumps there really is no good setup to run on the track without losing your air conditioning. :(
I had a few choices of what to do. First choice do nothing and hope the 402 holds up, but that just seemed foolish. Second choice was to add an accu-sump. Works for many people, but after looking into the dry sump it is hard to look at an accu-sump. Third and final choice build a different engine. :eek: I never really thought of a different engine until Johnny (shop manager for ECS) brought it to the table. He laid out what he thought was a viable solution and we started to look into pricing. Well at the end of the day the 402 idea was scrapped and now I am waiting for my 427 :D LS7 setup will allow me to have the dry sump and still keep the air conditioning. It is more HP than I need for the track, but since HP is controlled by right foot management it should not be a problem. I am actually kind of happy about the decision. Not just because of the A/C, but more so because a 427 sounds like it belongs in a corvette. Sure a 383 or 402 has plenty of power for the track, but when someone says 427 peoples eyes seem to light up. I will post up what we did to make a track car that we believe will be very reliable. Of course only time will prove or disprove that. :cheers: |
I think that is an excellent choice. I am thinking of selling my brand new dry sumped 5 liter that is in my GT1 car and drop in an LS7 and run NASA Enduros. The LS7 has less power, (505 vrs 570) but with the NASA rules, I could drop the weight to compensate for it.
Originally Posted by ghoffman
(Post 1563263462)
Oh and if you want we happen to have a 402 sitting around that might spark your interest since I know your car will not have A/C :D |
Do you know makes a plumbing fitting for the oil lines? It is a little plate that has the "goes into" and "goes outa" lines in one fitting with a retaining screw. I (and probably you) will need one that will allow Aeroquip type lines to the dry sump tank.
(Post 1563263858)
I will call you later. |
So you'll be going w/ a factory LS7/C6Z setup? That's definitely not in the cards for me so I guess the search continues...
-TJ |
(Post 1563267967)
-TJ Think of my setup as the big brother to the LS7, but yes that is what I am doing. Everyone I talked to said that without losing (or relocating) the A/C the dry sumps are really just bandaids and not worth the money to install. Believe me I was real close to saying lets go with the 402 with the LSA setup. I figured with the melling oil pump and that LSA it would be good for HPDEs, but I guess with doing 15 track days per year and the way I drive it just would not work. For me I was already into getting a new engine so the extra costs for the LS7 setup is still within my budget. If I had the 402 already I would be looking too. If I come across anything I will let you know. :cheers: |
So you (and others) felt the LSA type setup wouldn't get the job done? What did you think the system was lacking? I already ahve a built motor and (hopefully) won't be doing a motor build for some time. I'm starting to think I'm going to have to lose my AC... but not ready to do that just yet. I remember regretting it a lot on my '99 Z/28, but that was done only for weight and the weight savings vs. that car being my daily driver were just NOT worth it. However, in the case I'd be doing it for more reasons than just weight savings, and the Z06 is not a DD. But driving too/from THill in the summer still factors in.
-TJ |
I was Googling the adapters and I found these:
http://i67.photobucket.com/albums/h2...ffman/0040.jpg This is a cool website where they are putting a LS-7 into a 69 Camaro, and they are from here: http://www.lateral-g.net/g69/project/motor/ http://www.hotrodlane.cc/LS7/oilpanadaptors.html |
(Post 1563269798)
http://i67.photobucket.com/albums/h2...ffman/0040.jpg This is a cool website where they are putting a LS-7 into a 69 Camaro, and they are from here: http://www.lateral-g.net/g69/project/motor/ http://www.hotrodlane.cc/LS7/oilpanadaptors.html how much? and that build looks cool |
(Post 1563269335)
-TJ |
