F/S LS7 Rocker Arms w/bearing upgrade from Harland Sharp
PM sent
Originally Posted by john_sblendorio
(Post 1563791404)
PM sent
These look as though they would fit the LS3 also, does anybody know? Looks like the same straight and offset rockers.
Originally Posted by mikesul
(Post 1563802284)
THe LS3 has an offset rocker but from what I can tell they are 1.7 ratio.
Thats correct, the LS7 uses 1.8 :thumbs:
Sunday bump
Are these the stock LS7 ratio?
You say these would good "as an upgrade to your stock LS7 rockers". Do you mean just simply because of the Harland Sharp bearings, or because they have a different ratio from the stock LS7 rockers? The post by big bollas indicates that the LS7 uses a 1.8 ratio rocker for the OE rocker. TIA, Bob :flag: |
Originally Posted by BEZ06
(Post 1563827252)
My point is will these work with an LS3? Even if they are 1.8's they would be an upgrade to the LS3's 1.7.
any hp to be gained by installing or is it just more dependable setup
There would not be any HP gains. You just would not have to worry about needle bearings getting flushed throughout your motor! There are a couple of Harland Sharp stickers included....maybe worth 5-10rwhp. :lol:
Bump
I'm pretty sure these will not work on LS3's. The valves are different lengths and have different geometry I believe. Don't quote me though...
Originally Posted by 67camaro
(Post 1563864252)
(Post 1563864252)
