Front End Alignment
I am wanting to get my 77 aligned since I had it all apart. It drives fine but I wanted to get it done professionally. I checked with a couple of alignment places and they said their books didnt go back to 77 but if I had the factory spec's they could do the work. Can anyone post all the alignment specs. Thanks
thanks for the quick reply
You are welcome and good luck. :flag:
Take it to a Chevy dealership. They do alignments on Corvettes all the time and know how to do them. You can even call a local Corvette club to see which dealership they use....or they might recommend another alignment place that specializes in Corvettes. Stay away from the 'generic' alignment places if you don't know for sure that they have good experience with doing Corvettes. Also, make sure that you have fuel tank 1/2 to 3/4 full; you'd like them to align it with the weight you will normally see in the car (some even have "driver weight" bags they put in the driver's seat).
Originally Posted by wnmech
(Post 1563868513)
Originally Posted by Jud Chapin
(Post 1563868669)
Originally Posted by JP_80
(Post 1563873429)
Jud - I am a little confused (as normal :willy: ) about the instructions. They say the specs are symmetrical, which I understand for toe, but on caster and camber are they symmetrical also? Do you divide those numbers 2 also?
(Post 1563873429)
Sorry, JP, but I'm no alignment expert. But that info is put out by Vette Brakes and I'm sure if you call Gary, he'll be glad to help you. http://www.vbandp.com/ |
Originally Posted by I'm Batman
(Post 1563873499)
Toe is a total number across the car (1/2 for each wheel). Camber and caster are listed at the number you want on each wheel.
(Post 1563873530)
Thanks Batman - That's what I thought but figured it was better to ask than assume.
