Water pump question
Have a steady drip at the front of the block.. am sure its a water pump.
Is there a repair for it and are water pumps available ? Thanx for any help. Car is a 91 ZR1 |
Chris,
I have a new pump for sale. $320 plus $12 shipping UPS ground. Gasket not included. Jerry |
Originally Posted by ncChris
(Post 1563898543)
Is there a repair for it and are water pumps available ? Thanx for any help. Car is a 91 ZR1 Other than a new water pump no. Check with members here or on the zr1registry im sure someone has a spare. BTW 350-500 is the norm so be prepared for the sticker shock. |
I think Haibeck rebuilds them
Try Napa Auto parts |
water pump
Corvette Central has after market with gasket, 200.00 +shipping,then rebuild old unit..
Just asking, but, how do you know if your water pump is going out? What are the tell tale signs?
Originally Posted by LowFlight
(Post 1563908503)
The drip out of the weap hole or seal normally. |
(Post 1563898543)
[QUOTE=LowFlight;1563908503]Just asking, but, how do you know if your water pump is going out? What are the tell tale signs?[/QUOTE
with the front of the car raised the drip comes from the front center of the engine onto the balancer. It began several months ago with a drip once each minute. Now it's quite steady even when the car isn't running. |
I was asking because I now have a drip that leaves about a 50 cent piece size of coolant on the garage floor once every few weeks. Maybe three-four drips in the center between the tires...but I can't se anything and can't tell if it is from a hose/radiator or the pump. I pressure tested the system and it is fine.
Originally Posted by LGNDLT5
(Post 1563913922)
I also have new NOS waterpumps available @$275 shipped (continental U.S). Please email: john.sullivan@protective.com if interested. Note: I will have erratic email service over the next week FYI. John Sullivan :)
(Post 1563919644)
Check the clearance on the downhose to the thermo, mine was rubbing on the fan cover, put a hole right through it, this is the same hose that trashed the 24hr endurance run slowing them down.
How old are your hoses, could also be a loose clamp LGAFF 92 ZR1 #234 |
IS that the T shaped hose with the 90 degree bend? I am just trying ot figure out what could be leaking in the middle (water pump,Hose,Radiator)?
I paid $150 for mine at a local part store, its a rebuil but seems to be holding up just fine.
(Post 1563919644)
Originally Posted by Blown67427
(Post 1563934332)
This usually what happens when a car sits for a while. If it were the water pump, you'd know it. It would leave quite a few 50 cent pieces :D
Squeeze the hose and look for drops.(that sounds bad)
IT is the hose that comes of the crossover pipe and heads down i fI remember correctly, runs right boy the fan cover. LGAFF 92 ZR1 #234 |
(Post 1563934653)
That is why I hope it is a hose leak. It only leaks a few drops every few weeks and passed a leak check..so it must be a tiny leak. I don't know what happens when a LT5 water pump goes out. When I had my 96 LT1 and the water pump went...it blew out litereally. Dexcool all over the underside of the hood and it took my optispark with it. Totaled about $1200 in damage.
When a car sits for a while, especially going from summer to fall or winter, the hoses will react to the temp change, and a few drops will be the result. When the car is driven daily, the climate change is not much of a factor. Sometimes, it's just a matter of tightening the clamps a bit, and sometimes it stops on it's own. |
Well, I went out this afternoon to back it out of the garage to put new a new tag for this year on and noticed a few more drops on the garage floor. I opened the hood and right in front of the largest pulley on the bottom center of the engine on the Black cross frame it is wet with what looks like coolant. So, I guess it is the damn water pump. Right?
