? On Changing Ignition Lock Cylinder
I need to change my locks but when I order a new ign lock cyl will my current vats code work with the new lock cyl??:willy: (I know I will need a new cut key)
The lock cylinder will work with a key that has the same VATS pellet you have now. The pellet is nothing but a resistor so just make sure you order a blank with the proper pellet.
Bill |
(Post 1564000501)
Bill |
