Fuel Pump Replacement
Does anyone have the GM Labor Guide that tells the recommended install time for replacing the fuel pumps in both tanks?
2000 A4 Coupe Thanks! |
and why do you need this info , i have replaced the one in the drivers side it took about 30 to 45 min.
oak |
Originally Posted by oaks99
(Post 1564124570)
oak |
I was just hoping for the labor guide time. They're usually pretty accurate for the time it takes me to complete the task. thanks for the feedback.
CCP |
pump
OK I;am new to this. Why just replace the drivers side?
Originally Posted by pec98
(Post 1564150471)
Originally Posted by Corvette-Chris
(Post 1564124636)
I would also only change the drivers side
Pump on drivers side siphon jet on the other
Originally Posted by MIKE-C5
(Post 1564151835)
:thumbs: :iagree:
It should not take you more than an hour to do just the drivers side. It really depends on how much fuel you have to drain out the tank. The reason you would replace the driver side pump is because it is the pump that sends the fuel to the engine. The passenger side pump is only used to pump fuel from the passenger side tank to the driver side tank.
According to ALLDATA, the warranty time is 7.7 hrs. The retail labor is 10.8 hrs (does not include: drain & refill fuel tank).
Russ Kemp |
