lexan top cracking?
I was looking at my original Lexan top that developed a severe crack in the front just right of center along the edge. I thought I had either mishandled it or put stress on it when it was in the "trunk". I replaced it with a new one several years ago, and don't want another problem.
I use the top sometimes when I don't want the Z to sit out in the heat with the new top. Anyway, I noticed that when I tightened the front bolts the first few inches of the top flexed a bit. If I tighten it all the way to where the bolt seems to stop (very snug and firm tightening) I can see where the crack may have developed because of the mounting/tightening process. Have any of you had any problems with your tops from "overtightening" or maybe misalignment when replacing the weatherstripping???? |
you want to redjust the top. are you tightening the back bolts first. then finish tightening the fronts . one way to tell if you need tp adjust it is . start the back bolts to finger tight then try to start the fronts if they are hard to start then you need to redjust the frnt mounting brackets . he is a tip yo keep your lexan nice forever .spray and wipe in a coat of furnature polish with a damp cotton towel.it will keep it nice forever . also if you are parking the car in the sun take a bath towel and through it over the top and put the ends between the top and windows. sun kills lexan over a period of time.
Originally Posted by terryszr1
(Post 1564157766)
It fit really well with the old weatherstripping, but I have a really hard time getting it so "sit down" so I can start the bolts with the new ws. I keep the windows up and the top tightened down all the time now so everything will compress and seat properly but putting the top back on is a bear. |
