Just installed my yellow gauges (how to many pics)
In total it took about 30 minutes, but I have removed the pod surround before so that was simple. I will take some pics on the car later :thumbs: Extend the wheel all the way out and drop it to give you max space. Looking in the dark garage I had minimal glow but what I did have I liked. These are not cheap vinyl overlays that some have had bad expericances with. They are the same fit and finish as the oem faces.
Before taking on this project you need to understand it requires some abilities and patience, there is always the risk that things can go wrong or damage can occur. In the end if it all works out you will be a happy camper. The gauge companies instructions are here LINK They will also install the faces for only $20 (you pay shipping) http://qpcpv.tripod.com/IMG_3259.jpg Using a pry tool or a butter knife you need to release the bottom of the pod surround http://qpcpv.tripod.com/IMG_3245.jpg http://qpcpv.tripod.com/IMG_3246.jpg My trick to remove the three screws holding the pod using a stubby Phillips. I think this is much easier than trying to unclip the pod connector (the release is under the connector). Once the pod is in your hand it's simple to unclip the connector. Reinstall the pods in the surround and on reinstall it's simple to plug back in the connectors. http://qpcpv.tripod.com/IMG_3247.jpg Release the ignition switch either by unplugging it (green arrow) or releasing the side tabs (red arrows) you will also need to remove the sensor located below it to the left, it just pops off. http://qpcpv.tripod.com/IMG_3250.jpg You also need to remove or unplug the dimmer control, you can see the release points in this picture. http://qpcpv.tripod.com/IMG_3253.jpg Once the surround is off you can see all the mounting clips (the right pod has been removed). Make sure they did not get left in the dash, if so reinstall them on the surround. http://qpcpv.tripod.com/IMG_3251.jpg Remove the cluster, the white X marks the 4 screws http://qpcpv.tripod.com/IMG_3254.jpg http://qpcpv.tripod.com/IMG_3255.jpg http://qpcpv.tripod.com/IMG_3256.jpg http://qpcpv.tripod.com/IMG_3257.jpg http://qpcpv.tripod.com/IMG_3261.jpg http://qpcpv.tripod.com/IMG_3263.jpg http://qpcpv.tripod.com/IMG_3264.jpg Follow the instruction included on setting the gauges and the final needle height (look at the handle end of the tool, the correct height is the little step) http://qpcpv.tripod.com/IMG_3265.jpg Sweet :thumbs: http://qpcpv.tripod.com/DSC_0016.JPG Post to all the colors and more on how to order is on www.nakidparts.com |
Damn. Great write-up Ed, awesome How-to. It is sure is easier to get in to the C6 than it was the C5. The gauges look good. Looking forward to the installed pictures.
Paul :cheers: |
Wicked good write up Ed!
~joshua |
Fantastic. That is exactly what I needed. Thanks Ed!
Can't wait for my faces to arrive! |
Very nice. Be careful now:thumbs:
:thumbs: That look good
When you put the needles back on, do they go back in the same position? Any calibration needed?
Nice job Ed. :thumbs: :thumbs:
:cool: :cool: :cool:
Looks good. I'm patiently waiting for the pictures on the car. :)
Originally Posted by miroch
(Post 1564559961)
Removing cluster and resetting needle position about 100 times: 4 hours, and counting. Yes, I followed the directions to the letter. I know for a lot of people, it's a simple A-B-C. But be aware, there are some of us for which the procedure just didn't work that well, despite the directions. |
Originally Posted by PCMusicGuy
(Post 1564560025)
(Post 1564559961)
LINK They will also install the faces for only $20 (you pay shipping) Ed |
Originally Posted by Kent1999
(Post 1564560089)
Install: about 45 mins.
Removing cluster and resetting needle position about 100 times: 4 hours, and counting. (yes, I followed the directions to the letter, it just doesnt work that easy) |
:cool:
Originally Posted by talon90
(Post 1564559822)
Paul :cheers: |
I KNOW Some are in km/h JUST EXAMPLES. The first Z06 were cut today:cheers:
http://qpcpv.tripod.com/jpg White http://tmaxxpowerpipes.tripod.com/C6...LUSTER_PIC.jpg Red http://tmaxxpowerpipes.tripod.com/C6...LUSTER_PIC.jpg Yellow (YES) http://tmaxxpowerpipes.tripod.com/C6...LUSTER_PIC.jpg Tan http://tmaxxpowerpipes.tripod.com/product_images.jpg Silver http://tmaxxpowerpipes.tripod.com/C60642CLUSTERPIC.jpg Blue http://tmaxxpowerpipes.tripod.com/C6_06_34_CLUSTER.jpg Orange http://tmaxxpowerpipes.tripod.com/C6...LUSTER_PIC.jpg |
Originally Posted by Pipedreams
(Post 1564560152)
I am kind of thinking that once you install them and they reset themselves, you could just rotate them counter clockwise to get them where you want since the stop has been reset.
My needles were extremely tight, despite the fact that I rotated them CCW at least 8 rotations each before extraction with the tool (rotating during extraction as well, as the instructions stated). Most of the needles still came out with the pins attached. I just hope the guages are not permanently damaged. |
(Post 1564560303)
Thats what I would have thought too, but after literally dozens of reset attempts, they are still flakey. Seem to be ok, and then 2 or 4 power-ons later, they will 'reset' to be 80-120 degrees off.
My needles were extremely tight, despite the fact that I rotated them CCW at least 10x rotations each before extraction with the tool (rotating during extraction as well, as the instructions stated). Most of the needles still came out with the pins attached. I just hope the guages are not permanently damaged. |
(Post 1564560303)
(Post 1564560347)
If you have any issues contact the customer service and they will resolve them :thumbs:
I still love the mod, and will probably do it again if I can get this straightened out! Maybe RED this time... :) Thanks for offering this at a great price, Ed. |
