Need help - 68 "only" windshield chrome top header corners
Needing to replace or rechrome my w/s header corners on my 68 convertible. The potmetal of the originals is showing some bubbling. No one makes a repro because it appears to be one year only. The 69 and up shows a "notch" that my 68 doesnt have, but that sticks far under the top header stainless trim piece.
My question is will 69 up fit my 68 and is there any difference other than the notch that will be hidden anyway? If the part is totally different, let me know, but from all the pics I have seen, they mounting and screw holes look the same. Just dont want to order and return if someone has already tried this! Thanks resto board, Brad http://i267.photobucket.com/albums/i...igslist050.jpg |
Nobody knows?
To Wilcox - I see on your website the similar parts listed as late 68 and up. Other parts sellers list as 69 and up. Im sure someone has been down this road before. I can order parts and return them, but I hate to do that to a vendor and I dont like paying shipping two ways just to take a look. Thanks for any help, Brad |
The 69 windshield chrome will work but has the notches. Why don't you just rechrome yours. Get the plater to fill in the pits and it should work. You'll have to put in new plastic bushings. I have some used ones but It'll take a while for me to find them and I'm not that far yet in restoring my 68. Thanks, grant
Hey grant - I can have them rechromed but 75-85 each and I can buy new repops for 90 for the pair. I know the newer version has the notches, but without holding one in my hand, it looks like the notch would be UNDER the top header trim piece and therefore wouldnt matter. My concern is that if the 69's would fit the 68's I would think the parts sellers would say that they fit ok.
Originally Posted by bigredbrad
(Post 1565053948)
Hi Grant - please send pics to bigbrad@alltel.net. cant wait to see them, Thanks, Brad
Forgive my ignorance, but the 68 that I restored had a totally different piece here. The tab with the hole that holds the plastic grommet was a separate piece that attached to the main chromed piece that you are refering to. I would rechrome no matter the cost unless your car is just a driver, NOM etc. Better quality chrome than you will get from the repro and will likely last much longer. JMHO
Hi
:iagree: The once shown are not 68. 68 used a flat top piece ( no notch ) and a separate top pin receptacle with the nylon bushing. This pieces are more than rare , nearly impossible to find. Once in a while, a guy on E-bay sells them new, most probably home made reproduction. look original and are OK, but expensive ( 200 USD + ) just for the pin receptacle pieces. The trim pieces are not available, must be rechromed. If they are pitted, it is difficult also for a rechromer to fill this due pot metal. If your happy with the style shown, buy them new . They will fit , but are not correct replacement style. Rgds. Günther |
I think the ones pictured are late 68. There were 2 or 3 different upper windshield frame corners used on 68's. If I remember right, I think my 72 GM Parts Book might even show a variation for coupe and convertible at some point in the year (the parts book is in my shop, I'll try to look when I get in monday). As described by wesch and 68 charcoal, most 68's have a 2 piece corner, with a seperate top casting and receiver (similar to the receiver used on 63-67's). I have 2 friends with very early VIN 68's (one's #74 and I think other is 178) and these have corner moldings that appear different than some used ones that I have in my shop. Like soooo many other things on 68's, not only were many one year only parts, but many had numerous variations to them throughout the year.
These were removed from my very late 68. I dont know for 100% sure, but believe them to be original to the car. Everything else I have removed so far has been. These were really stuck on tight and the w/s post underneath is in green primer. All the screws holding the top w/s stainless and the corners appeared to also be original.
bigbrad |
early 68 has the two piece ones, late 68 has the one piece.
I have had cars with both types. |
Originally Posted by Road-Race Vette
(Post 1568291597)
Originally Posted by AWilson
(Post 1568578036)
My very early 68 has the two piece. I also was told that they changed later in 68. The op probably has originals.
http://www.roald.dk/billeder/joe/silver3.jpg |
Yep. If you look, you'll see where the two phillips head screws attach the reciever (with the nylon bushing in it) to the windshield header top corner molding. The late 68 and the 69 up corner moldings have the reciever cast in one piece as part of the molding, like those at the beginning of this post.
Originally Posted by Ronaldo
(Post 1568579162)
1 Attachment(s)
I am resurrecting this old thread because I find myself in the same dilemma. In my case I have a '68 coupe with a Jan 28 build date. I have two sets of these upper corner molding pieces and the set that I thought came off my car is the set in the photo. However, when I tried to see how they fit I found they didn't want to go in at all. Neither does the other set that looks similar except it doesn't have the notch in the part that goes under the center trim piece. But it does have the ring that is integral (both are one piece cast pot metal). I'm wondering if neither of these were from my car and I will have to find the two piece type. Does anyone know when that change took place? I'm s/n 409725. As a side note I purchased my car largely disassembled (yes, I know that was dumb) so I am having to guess and/or do extensive research part by part. Any help regarding interchangeability and running change dates or s/n's for these moldings would be greatly appreciated.
Following up on my own post now that I look at the picture it doesn't make sense that that piece would have had that J nut installed in the notch if it actually came off my car, since there is no provision to use it. I am still stumped because the other set I have without the notch doesn't seem to fit either. (I originally sent that photo to a plater to get a quote on replating and used the dollar for scale purposes.).
I bought two of the GM replacement corners for my 71 coupe and was not happy with the fitment.....I sent them back and had my originals plated. I was much happier and the finish is much better than the replacements.
If you plan to have the car judged you will want to make a note with the plating company to not polish the lower part by the pin as this was slightly rougher from the factory. Kevin |
Originally Posted by 68/BB
(Post 1587579691)
thanks |
I'd say yours is late 68 but not sure. they did make changes thru 68 some have different than others. I have 2 piece early 68. I'm in same boat as you cant find those or windshield moldings either. I decided to re-chrome but don't know where to go to do this. good luck
