Dana 60 IRS
I thought you guys might want to see what is probably one of the strongest IRS setups around. This setup is similar to Jim Moore's (427Hotrod) 67 Convertible assembly. I purchased the assembly two years ago from an NHRA class racer. I had planned to run the setup in my car, but life got in the way and I have sold my Corvette. I had the trailing arms and rearend rebuilt by Mike Dyer (tracdogg2). The Crossmember Bushings, Trailing Arm Bushings, Trailing Arm Seals and Bearings have been replaced. The U-Joints are Spicer 1480 Non-Greasable units and are brand new. Almost all pieces are powder coated. The Dana 60 Unit is a spool with a 4.88:1 gear ratio. I don't think that you will find a stronger IRS setup than this. The assembly is ready to bolt in to any C2 or C3 chassis. I am asking $5100 OBO. If you want to run hard at the track with an IRS and not worry about the rear end, this is the kit for you.
Send me a PM or email if you are interested. http://i295.photobucket.com/albums/m...re_front_2.jpg http://i295.photobucket.com/albums/m...are_rear_1.jpg IMG]http://i295.photobucket.com/albums/mm136/vetmaniac1/dana60_front_2.jpg[/IMG] http://i295.photobucket.com/albums/m...60_front_1.jpg http://i295.photobucket.com/albums/m...ra_parts_2.jpg http://i295.photobucket.com/albums/m...a60_rear_1.jpg http://i295.photobucket.com/albums/m...a60_rear_2.jpg http://i295.photobucket.com/albums/m...a60_side_2.jpg http://i295.photobucket.com/albums/m...out_axle_1.jpg http://i295.photobucket.com/albums/m..._bushing_1.jpg http://i295.photobucket.com/albums/m...are_side_1.jpg http://i295.photobucket.com/albums/m...ra_parts_1.jpg http://i295.photobucket.com/albums/m..._bushing_1.jpg |
Wow that looks beefy, very cool. :cool:
Good luck with the sale. :yesnod: |
For anyone wondering how this compares in terms of pricing to the strongest assembly that Tom's offers, here is the breakdown:
12 Bolt 3rd member $2900 1480 Axle Kit $2255 H.D. Rear Cover $ 130 Assemble Trailing Arms $ 325 Crossmember Locator Kit $ 74 Rear Camber Control Rods $321 Total $6005 Other items included: Poly Diff Bushing Kit (Eckler's) $ 25 Crossmember Cushions (Eckler's) $120 Spring Bolts - Long (Eckler's) $ 20 Grand Total $6170 Ultra Rare Baddest of Them All Dana 60 IRS Setup $5100 I am inclined to think that over $1,000 less for a far, far stronger unit is a pretty good bargain and don't forget the :cool: factor due to it being quite rare. |
Originally Posted by VETMANIAC
(Post 1565071049)
12 Bolt 3rd member $2900 1480 Axle Kit $2255 H.D. Rear Cover $ 130 Assemble Trailing Arms $ 325 Crossmember Locator Kit $ 74 Rear Camber Control Rods $321 Total $6005 Other items included: Poly Diff Bushing Kit (Eckler's) $ 25 Crossmember Cushions (Eckler's) $120 Spring Bolts - Long (Eckler's) $ 20 Grand Total $6170 Ultra Rare Baddest of Them All Dana 60 IRS Setup $5100 I am inclined to think that over $1,000 less for a far, far stronger unit is a pretty good bargain and don't forget the :cool: factor due to it being quite rare. Don't forget that for Tom's setup, you'll also need to provide your own case.. The case is not included in Tom's price.. |
:cool: :flag:
that looks liek the old Peppy's (Peppy Astrada) setup that was used extensively in HHRA/IHRA SS in the 60's and 70's until a total backhalf of the car was legalized
Originally Posted by vetteman9368
(Post 1565089988)
Someone ought to grab this thing. I know mine has been killer!!
JIM |
Dana 60 Rear End
I may be interested! My '66 recently blew its rear end and I'm looking for a replacement. I would like 3.07 gears in it though, because I have a Richmond 5-speed with 3.28 first gear. The rear end I had in it was a 1981 alluminum and the ring gear bolts came loose and one sheard off causing a hole in the case and untold damage to the pinion. I built the engine with about 600 horses and I race it a couple of times a year on the drag strip. Please let me know if you think I can get this to work for me.
Thanks, Brandt Hulderman |
This thread is over two years old, I wonder if it's all still for sale?
It was sold not long after this post along with the 632" motor that was built to go in front of it. It went to a Forum member in Arkansas. I spoke to him recently and he now has a car to put it all in so he's keeping it.
They still show up from time to time. I just talked to another Forum member last weekend who recently found one at a swap meet. It had a 30 spline posi in it instead of a spool and 4.10 gears. He snatched it up for a street rod project he is building. Not for sale..I tried! Meanwhile....I'm still beating on the one in may car after many years and haven't touched it. Just did a 2500 mile road trip with it last week! JIM |
Rear End Solution
Found something that will work. Going with 9" Ford rear end with extra heavy duty control arms. By the way, this is a show and go car. I can request a shortened 55" hub to hub, which will allow me to run 325/50-15's. Ring and Pinion ratios range from 2.5 to 4.5. I'll get 3.0+ which will give me the following velocities (mi/hr) vs. RPM in each gear:
RPM - 1st Gear - 2nd Gear - 3rd Gear - 4th Gear - 5th Gear 500 4 6 9 11 14 600 5 7 11 13 17 700 6 9 12 16 19 800 7 10 14 18 22 900 8 11 16 20 25 1000 8 12 18 22 28 1100 9 14 19 24 30 1200 10 15 21 27 33 1300 11 16 23 29 36 1400 12 17 25 31 39 1500 13 19 26 33 41 1600 13 20 28 36 44 1700 14 21 30 38 47 1800 15 22 32 40 50 1900 16 24 33 42 52 2000 17 25 35 44 55 2100 18 26 37 47 58 2200 18 27 39 49 61 2300 19 29 40 51 63 2400 20 30 42 53 66 2500 21 31 44 56 69 2600 22 32 46 58 72 2700 23 34 47 60 74 2800 24 35 49 62 77 2900 24 36 51 64 80 3000 25 37 53 67 83 3100 26 38 54 69 85 3200 27 40 56 71 88 3300 28 41 58 73 91 3400 29 42 60 76 94 3500 29 43 61 78 96 3600 30 45 63 80 99 3700 31 46 65 82 102 3800 32 47 67 84 105 3900 33 48 68 87 107 4000 34 50 70 89 110 4100 34 51 72 91 113 4200 35 52 74 93 116 4300 36 53 75 96 119 4400 37 55 77 98 121 4500 38 56 79 100 124 4600 39 57 81 102 127 4700 39 58 83 104 130 4800 40 60 84 107 132 4900 41 61 86 109 135 5000 42 62 88 111 138 5100 43 63 90 113 141 5200 44 65 91 116 143 5300 45 66 93 118 146 5400 45 67 95 120 149 5500 46 68 97 122 152 5600 47 70 98 124 154 5700 48 71 100 127 157 5800 49 72 102 129 160 5900 50 73 104 131 163 6000 50 74 105 133 165 6100 51 76 107 136 168 6200 52 77 109 138 171 6300 53 78 111 140 174 6400 54 79 112 142 176 6500 55 81 114 144 179 http://www.kugelkomponents.com/produ...726_500pxw.jpg |
bdhulderman, how did it go with that rear suspension setup? Is that a Heidts peice?
Btw, i drool everytime i see the dana 60 pics in this thread! |
That Dana 60 IRS in the OP looks like what the Hemicuda should have had for wheelie duty.
