Need Help Identifying Engine
According the previous owner, the '73 I recently acquired does not have the original small block motor. He said his engine builder told him the current block came out of a Chevelle but he wasn't sure it was even the original motor for the Chevelle. He also said it was supposed to be a 4-bolt main block.
Here are the numbers I could find on the block: Found on the drivers side rear near the firewall facing up and reading left to right from the drivers side: 25 GM 3970010 (the "25" is turned 90 degrees clockwise and so is readable from the drivers side fender) Found on the passenger side near the firewall under the distributor and also reading left to right from the drivers side: F 6 3 There's a little space between each of these but nothing else apparent in between. Found stamped on the front passenger side pad: CE3A57 4 1 The C and E are very hard to read. The C could be an O or 0. The E could be an F. I suppose the A could also be a 4 but it doesn't look like the next 4. The last 4 and 1 are not near and don't line up with the other numbers and are also not beside each other and don't line up with each other. I also found some markings on the block under the distributor on the drivers side: 1. There is a circle of 10 raised dots with a tear shaped pointer pointing at one of the dots and somewhat toward the front of the engine. The third dot clockwise from the one being pointed at has a second dot beside it just outside the circle. 2. Near the above circle of dots is three letters arranged in a circle 120 degrees apart. There is a "T", a "D", and an "N". There is a tear shaped pointer pointing at the N. There is no pad and no numbers on the drivers side front of the engine block. So, what do I have? DC |
From what I know a CE block is a service replacement. The 010 is a 350. Someone else can help you with the other numbers you provided as to the year.
Try this link http://www.mortec.com/
It will help with block identification |
Originally Posted by hgm
(Post 1565230530)
It will help with block identification The Mortec site didn't help with the other numbers. I was able to find some info on another website that said the circle of dots is a "casting clock" and probably means the block was made in the Saginaw plant. There are 10 dots because of the 10 hour work shifts. The pointer points to the beginning of the shift and the extra dot outside the circle is the hour the block was cast. So, if I'm interpreting that correctly, it means my block was cast in hour 4 of the workday of June 6, 1973. That leaves the "25" and the T, D, N circle to explain. I would also like to know if it is possible to decode the CE number on the passenger side front pad. DC |
Bump
ce means an over the counter gm crate engine also used for warranty replacements which would be a gm crate engine ordered aswell
Originally Posted by 400hp427vette
(Post 1565245830)
DC |
Nothing I know of, Call gm they should have an idea
Originally Posted by DC3
(Post 1565246081)
I received a PM from karol with a link (http://www.nastyz28.com/chevy-engine-code-stampings.php) to a website confirming your description of CE. Is there anyway to decode the numbers after the CE?
DC |
Originally Posted by lr172
(Post 1565246831)
I have a CE bloack as well (512). To my knowledge, the first digit is the year built and the rest is just an engine serial number.
That leaves the "25" and the T, D, N circle to explain. Anyone? Any easy way to determine if this is indeed a 4-bolt main block? DC |
(Post 1565253904)
Any easy way to determine if this is indeed a 4-bolt main block?DC
No ... AFAIK, there is no way to KNOW whether 2 or 4bm ... without pulling pan & looking at caps. AKAIK, all the decoding & chasing numbers ain't gonna tell you. |
Originally Posted by jackson
(Post 1565253994)
you have a CE block.
No ... AFAIK, there is no way to KNOW whether 2 or 4bm ... without pulling pan & looking at caps. AKAIK, all the decoding & chasing numbers ain't gonna tell you. I guess the "25" and the T, D, N circle has everyone stumped? DC |
yes i know what its for --its for when it was made --day or night shift yours is night shift.,and if theres a circle of dots and its pointing to one of them thats the time it was built.HOpe that helps.
one other thing to the circle of dots and arrow pointing to the dot is when the shift started the double dot is the time it was cast. |
Originally Posted by PatsLs1vette
(Post 1565261340)
yes i know what its for --its for when it was made --day or night shift yours is night shift.,and if theres a circle of dots . . .
So, you are saying the N references night shift and the D references day shift? Then what does the T mean? I guess the story of my engine begins with "It was a dark and stormy night". :D DC |
