Touch Up Paint
so im noticing that Im getting some stone chips on the front of the car and I went to the dealer to buy some touch up paint in the the little container that has a small brush and a ball point tip on top. Im wondering what is the best way to approach this as far as doing it correctly for small scratches and small stone chips?
Always a good time ... I take the brush and drop some paint on a piece of waxed paper then use the end of a toothpick to get a small drop of paint. Seems to work best for me. Make sure you take the time to shake the tube well :cheers:
Originally Posted by mrm1149
(Post 1565250122)
Sounds good. Also, several extremely thin coats instead of a blob. |
Originally Posted by alanhang
(Post 1565250031)
You might want to check this out. http://www.touchup123.com/ I've used it on my '04 ... worked really well...and easy, matched paint perfectly. |
Touch Up
WOW, has anybody else tried this?
Originally Posted by Ron222
(Post 1565251198)
Alan,
You might want to check this out. http://www.touchup123.com/ I've used it on my '04 ... worked really well...and easy, matched paint perfectly. Mines Pewter and hard to work with but the kit does wonders. |
Ron, Is The Filler Permanent Or Do You Need To Repeat The Process When The Color Washes Out Of The Pits. Ive Got A Jetta Daily Driver That I Would Like To Try This On.
Alan,
I have the same touch up (ball point pen top) and really like it. Put a few test spots on a piece of paper to get the paint to flow effortlessly. After that, a steady hand hand and light pressure application really takes care of the stone chips. I've only had to use it a few time (luckily), but each turned out terrific where I can barely tell there was any imperfection. Once again, a steady hand and right amount to fill the chip is key. A day to dry and coat of wax and I think you'll be happy. |
Touchup123 worked well for my black car.
Originally Posted by UWEBABY
(Post 1565251980)
Originally Posted by Marv's02
(Post 1565252365)
Alan,
I've been using Langka kit....
http://www.langka.com/ It's not a perfect solution, but it's much better than plopping drops of touch-up paint on and walking away. On minor scuffs & scratches, I've been able to make these virtually invisible (you can't find them afterwards). On deeper stuff - takes more patience and a couple layers (touch-up paint tends to shrink). I like it..... |
(Post 1565257902)
are you using the pen on top or the brush??
(Post 1565257902)
Originally Posted by Janster
(Post 1565258860)
http://www.langka.com/ It's not a perfect solution, but it's much better than plopping drops of touch-up paint on and walking away. On minor scuffs & scratches, I've been able to make these virtually invisible (you can't find them afterwards). On deeper stuff - takes more patience and a couple layers (touch-up paint tends to shrink). I like it..... Lanka for me. I've used it and if you follow the directions to the letter, you will have positive results too. |
(Post 1565261470)
Also, make sure you unscrew the top and take out the plastic flow inhibitor before testing....took me a few minutes to figure that out. Once you do that and a few good shakes...you should be ready to go.
