The N/A Corvette Fast List
The plan is to have a list of the fastest n/a cars. This is not a debate thread. You can email me any questions/concerns,etc.
The rules are simple. Any vette, any year, any motor, any weather, just NO power adder. Car/driver listed only once unless you have more than 1 car. I'll start by keeping one single list of the Top 30 cars. We can separate the body styles out(ie. c2,c3,c4...) into separate lists if there's a big enough interest. Please list: Car/year Motor type/size Suspension Tires Approx. raceweight Transmission type DA if known Track ET and mph ********************* TOP 30 FASTEST N/A CARS ******************* -----ET/MPH------------DRIVER-------------MODEL/YEAR------MOTOR-----TRANS. _1) *8.19 @ 165.42---[Rockin'Al]-------------'85 [C4]---------440ci.-------man. _2) *8.49 @ 16X.XX---[DBN]-------------------'00 [C5]---------418ci.-------auto _3) *8.65 @ 151.82---[Rick@MorosoPerf.]---'61 [C2]---------363ci.-------auto _4) *8.77 @ 150.15---[SS/AA324]------------'69 [C3]---------427ci.-------auto _5) *8.90 @ 152.XX---[SpeedyGjr]-----------'74 [C3]---------632ci.-------auto _6) *8.98 @ 153.XX---[tensecvet]------------'86 [C4]---------565ci.-------auto _7) *9.10 @ 147.50---[wheelsup]------------'91 [C4]---------414ci.-------auto _8) *9.19 @ 148.XX---[red79vette454]------'79 [C3]---------565ci.-------auto _9) *9.22 @ 150.20---[Sebast19x]-----------'08 [C6]---------427ci.--------man. 10) *9.24 @ 150.35---[2000-A4]-------------'70 [C3]---------427ci.--------auto 11) *9.32 @ 145.XX--- -[robz]--------------------'03 [C5]-----------388ci.-------man. 12) *9.45 @ 141.00-----[Capthuff]---------------'99 [C5]-----------427ci.--------auto 13) *9.46 @ 139.80-----[stanger383]------------'07 [C6]----------427ci.---------auto 14) *9.53 @ 145.13-----[redvette1077]----------'98 [C5]----------427ci.---------auto 15) *9.54 @ 139.69-----[hookedup]--------------'90 [C4]----------420ci.---------auto 16) *9.62 @ 137.90-----[hookedup]--------------'66 [C2]----------383ci----------auto 17) *9.70 @ 137.64-----[hookedup]--------------'69 [C3]----------454ci.---------auto 18) *9.79 @ 139.92-----[mackeyred96]----------'96 [C4]----------412ci.---------auto 19) *9.80 @ 141.XX-----[Pete@Champion]-------'06 [C6]----------502ci.--------auto 20) *9.81 @ 142.46-----[LS7 BUD]---------------'06 [C6] ----------427ci.--------man. 21) *9.82 @ 133.67-----[Beach Bum]------------'06 [C6]-----------427ci.--------auto 22) *9.85 @ 134.74-----[65 Vette 7327]---------'65 [C2]----------383ci.---------auto 23) *9.86 @ 140.9X-----[Jared @ RPP]-----------'06 [C6]----------427ci.---------man. 24) *9.87 @ 138.70-----[GARY2004Z06]---------'08 [C6]----------427ci.---------man. 25) *9.88 @ 138.XX-----[INSANITY]--------------'93 [C4]----------434ci.---------auto 26) *9.90 @ 141.40-----[427hotrod]-------------'67 [C2]----------540ci.---------man. 27) *9.90 @ 136.42-----[GrandSportC3]---------'68 [C3]----------434ci.---------auto 28) *9.93 @ 13X.XX-----[Black MTI]--------------'00 [C5]----------427ci.---------auto 29) *9.95 @ 135.61-----[Redgar]-----------------'99 [C5]----------427ci.---------auto 30) *9.95 @ 137.81-----[stealth99c5]------------'99 [C5]----------441ci.---------auto |
I'll jump in first.
'67 Convertible Street Cruiser 540"- Pump gas Dana 60 IRS- 3.07 gears 28x10.5 MT slicks 3650 lbs 5 speed stick DA-Unknown- it was bumping 90* and feeling a little muggy. Bowling Green Ky- Beechbend 9.90-141.40 mph |
1968 Coupe
427/435. Stock Heads,compression, intake, carbs, cam lift, compression, .070 over, stock stroke, JE stock replacement pistons Stock IRS with Tom's 12 bolt center, QA1 shocks 9x30 Hoosier Radial Slick 3465lbs TH350, manual valve body, no brake, 8" ATI converter 1350DA No Problem Raceway, Belle Rose, LA 10.27@ 131.70 http://img.photobucket.com/albums/v6...elleRose08.jpg |
Hey I may as well get my name on the list in the "TOP TEN" early :D I want to see how long I last.. (will I make it until tomorrow night):rofl:
12.28 @ 112 mph ...Ran it at ETown in "Killer" air 1996 350ci Stock everything except gears and converter... Mods...1.6 RR The heads have never been off the car....as of now I'm #3 on the list... |
You know, I'd be dangerous IF I was to work that hard to maximize my parts like you Stocker type guys! I can't even imagine what's left in mine...but I bet it's nearly a half second!! That's just depressing! Love that car!!!
JIM |
I'll be the first to bump JP. :D ;)
2006 Corvette 6.0L LS2 with Vararam, 160' thermostat, Cartek tuning Stock suspension Stock tires 6 speed automatic trans Roughly -300 foot DA Approximate raceweight - 3410 pounds Atco Raceway 12.07@117.45 |
Originally Posted by 427Hotrod
(Post 1565395750)
JIM |
My best is in my signature. :( to say, my wife has a better time. The motor is stock on bottom end. Hand ported heads, bigger valves, hotcam, electric waterpump,long tubes, stock exhaust except for magnaflow mufflers. 3,000 stall yank converter, 4.09 gears tuning by pcmforless, and Mackeys old wheels and tires!!
Runs were made at Richmond Dragway. |
on the list for now...
'99 FRC
race weight-3165lbs 346ci LS1 w/ stealth II cam, kooks headers, ls6 intake and vararam lowered on stock bolts w/ bilstein shocks and z06 sway bars M6 w/ luk pro gold clutch and 4.10 gears DA unknown Texas Motorplex 11.62@118.35 |
Thanks for putting this together Rob :cool: though I know that mine and Panuzzo's time on that list will be very brief. :D
Originally Posted by LS1LT1
(Post 1565399471)
(Post 1565399471)
Does that count :) |
98 coupe, 176,000 miles on it, stock bottom end w/cheap Patriot heads & a semi mild cam (under .600 lift) A4, 3.32's & 4400 stall.
1.53 60' 7.08 1/8 11.38 1/4 at 116 MPH. |
Here's mine:
1/8 7.49 @ 94.88 1/4 11.65 @ 118.76 |
Do me a favor and write down the size of motor in ci. for continuity and state c2,c3,etc..
Thanks Keep your posts complete like the format in the original post. I'm going to just list et,mph,driver.motor until the lists build up to avoid having to keep changing things. |
Car/year.................GrandSport 96
Motor type/size........LT4/396 Suspension..............Stock type with polly, QA1s' Tires......................BFG Drag radials 315/35/17 Approx. raceweight...3500 w/driver Transmission type.....Auto 700r4 DA if known.............-1200 Track.....................Englishtown ET and mph.............10.82@124 |
2000 Corvette Coupe
LS2 366 ci Suspension: Stock Tires: MT ET Drag Radials 255/50/16 Approx. raceweight 3550 Transmission type: A4-RPM Level V DA if known.. N/A Track: ATCO ET and mph: 10.49 @ 129.38 |
Here's the rest of my info I didn't add last post:
Car/year 1996 CE LT4 Motor type/size 350 Suspension Stock Tires MT ET Streets/skinnies Approx. raceweight 3340 with driver Transmission type ZF6 DA if known don't know Track Fayetteville Motorsports Park ET and mph 11.65 @ 118.76 |
Car/year 05 C6 Z51
Motor type/size LS2 6.0 364 ci Suspension stock IRS BFG drs P295 X 35 X 18 Race weight guess 3500 LBS Trans type A4 DA +300 Race track Atco N.J. ET/MPH 10.927@ 123.63 |
Car/year 2000 C5
Motor type/size LS1 346 Suspension all stock Tires 16" CCW Drag Pack 255/60/16 M/T Approx. raceweight 3450 W/ me Transmission type RPM A4 DA if known -400 Track E Town ET and mph 10.61 @ 124.5 |
