How to fix p0113 and p0103 code
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage Anyone know how to fix this?I am guessing a new MAF? |
What year is the car? How many wires on the MAF? Trying to determine if you have the IAT sensor built in. Could try cleaning it with MAF safe cleaner before replacing. Anybody working on the car recently?
Check the plug that goes into the MAF. From those two codes, it sounds like it's loose.
Check the couplers for air leaks as well. If none of these fixes the codes, I would check the intake manifold for any crushed gaskets. I had the same issue a while back and it turned out to be the intake gaskets.
Originally Posted by BLOWNBLUEZ06
(Post 1565484396)
Originally Posted by LinearX
(Post 1565484874)
