Water pump bolts?
Should I put some antiseize on the water pump bolts or any type of tread sealer when installing the new pump? :smash:
just clean em and put some thread locker on them. i believe its 22ft lbs for torque spec.
I don't use loctite on them, service manual calls for dry installation. Tighten in two passes, first pass at 11 lb-ft, second pass at 22 lb-ft.
Mine were showing early signs of corrosion. Anti-seize. :yesnod:
100000 miles and just replaced mine bolts came right out.
