113's Or Vortec’s
So I’m just about ready to buy a new set of aluminum vortec heads, but I just stumbled across a site that said my 113’s are just as good on the flow bench. I though that good flow numbers and better ports where the vortec’s main selling point. So I’m a little confused.
The motor is a stock bottom end, and will go with a LT4 hotcam and a TPIS miniram. What do you guys thnk? |
I don't know the flow numbers on the Vortex heads but comparing those numbers is the way to make your decision.
Remember that our #113s brought an extra 10chp over the 128s and a good porting job will add say another 30chp. How much power will the Vortex add over the stock #113s using similar intake setup?? |
I would stick with the 113's and maybe upgrade them or go with a good set of aftermarket heads.
i remember an article here on the board
about a crazy powered L98 ... that was done using Vortec heads.- Are the Vortecs better than edelbrock heads ? |
If the 113's flow the same as Vortec's what the need for a poll? This is a no brainer.
because im not confident in the accuracy of the data
A stock 350 bottom end @ 6000 rpm only needs ~230 cfm per cylinder.
The 113's in stock form get about 195cfm. Good porting will get you close - depending on the porter. TPiS claims 250+cfm after porting. I haven't seen real-world numbers to support. I don't know the #'s for the Vortecs but hear they are good for mild-motors and efficiency. Any head you look at needs to hit these modest numbers. If you want to change the short-block some day, that might change your considerations to a better head. |
The heads that GM touts as the "Alum Vortec" heads are infact the GM "Fast Burn" heads.
The only thing they have in common with the cast iron Vortec's is the intake bolt pattern. They use LT4 valve train parts (hollow valves, springs, retainers). They are vastly superior OTB than the stock L98 113 castings. The 113's can be ported to perform as well as the fast burn heads, but once you spend the same amount of $$ on the fast burns... they are vastly superoir again. Drawbacks to the Fast Burn heads include the intake bolt pattern, which require an expensive Vortec specific lower TPI intake. Then there is the fact that for the money there are numerous aftermarket heads that will out perform them and don't require anything special. Brodix KI180/200, Dart, World ect. Will |
Originally Posted by Calderone
(Post 1566012947)
Are the Vortecs better than edelbrock heads ? Stock 113's @ .600" - 199/167 Vortec L31 @ .600" - 222/152 Edelbrock Performer @ .600" - 244/183 |
Compare the .200 to .500 numbers for a street car. Not thrilled with the Performer heads.
Lots of Vortec heads out there going 240+ right out of the box. Avoid the 906 casting, the exhaust sucks no matter what you do. |
As cuisinartvette stated its not about the max flow number, its the 100-600 lift figures, or low lift,mid, and high lift numbers. I would choose better heads.
awhile back i ported a set of 113s & managed 228@.500 on the intake and 196@.500 on the exhaust with mid lift moving up similar percentages. with a miniram and 503 cam it sent a 6spd car to 12.7@110mph. the chambers are dated on a 113 though. if you could get a vortech style MR the edelbrock etec 170cc head is a very good choice.
Originally Posted by racebum
(Post 1566016600)
Very good! Any tips or pics on the 113? He also mentions that the exh sould flow ~80% of the int, so porting is often needed for best results. |
i have pics but none of them are really going to show you where the work was done. the short turn radius in the intake is thick enough that you can smooth and reduce the turn angle slightly giving it a straighter shot at the runner. use cartrage sanding rolls in the bowls and short turn. bits could be used at first to match the intake to the manifold. a good valve that's necked down helps. manly race-flo in the stock sizes were what i used. a good 3 angle job is also needed. radius the metal holding the guide...this is a bizatch to do but the aluminum holding the guide is thick and somewhat intrusive. smooth the intake runners & do the above mentioned. if you haven't ported before do watch the standard abrasives video first. in the chamber your big goal is to get some of the overhang gone, like back by the spark plug where the valves sit. polish the metal up & use sanding rolls back there to open up the area. with a good valve job and 4-5hrs spent on each head you could achieve similar. i sold those heads awhile ago & replaced them with a pro action 180cc casting. heads suck out of the box assembled but they can perform if a machine shop specs the guides and you use a decent valve. the same car now goes 12.4@113 and may have more with a good tune. in my experience edelbrock is one of the few heads i would run right out of the box and not think twice about it. AFR's cnc'd spec to build stuff is also supose to be really good but most likely out of your price range based on the heads you are considering.
(Post 1566023647)
...In my experience edelbrock is one of the few heads i would run right out of the box and not think twice about it.
Since Edelbrock's aren't listed as polished (intake/exhaust/or bowls) and since their flow numbers would decrease somewhat after head-milling (to 58cc), what fancy's you about their out-of-the-box performance? Why didn't you pick them for a replacement? I'm not challenging their value -- just asking for elaboration. gp |
113# about 199....Vortec about 240. Vortecs were designed along with the LT1 heads, and flow very well, especially in the low-lift areas. They need some machineing mods for higher performance use, but for milder cammed motors they're good, stock. There is that pesky Intake Manifold problem.
GREGGPENN...milling the heads doesn't generally have much effect on the flow. :chevy |
(Post 1566015443)
Lots of Vortec heads out there going 240+ right out of the box. Avoid the 906 casting, the exhaust sucks no matter what you do. @.200 120/100 @.300 163/129 @.400 189/148 @.500 199/164 @.600 199/167 Edelbrock Performer @.100 73/61 @.200 140/108 @.300 200/144 @.400 238/163 @.500 244/175 @.600 244/183 Vortec L31 Iron @.100 58/43 @.200 114/88 @.300 173/125 @.400 216/143 @.500 225/149 @.600 222/152 BTW the AFR heads outflow all of these big time. |
Originally Posted by GREGGPENN
(Post 1566024927)
Based on your times, it sounds like you did a good job with your porting. Well done!
355 Hp 405 Tq
ZZ4 v Fastburn 385 crate carb engines
Same block , same cam ZZ4 w /113 heads ;355Hp / 405 Tq @10:1 385 w /Fastburn heads ;385Hp / 385 Tq. @ 9.6:1 Makes 435Hp w /Hotcam. http://sallee-chevrolet.com/ChevySma...leeZZ430HP.cfm The cast L31 Vortec heads #12558060; 170cc / 64cc Chambers / 1.94-1.5 are not the aluminum vortec heads (Fastburn ) that the OP mentioned From another site, "The Fast Burn heads feature a raised intake port that measures 210cc. Normally, we'd say that 210cc is kinda big for the street, but GMPP did their homework on this head and combined it with smaller than normal valves (2.00 intake, 1.55 exhaust) and an efficient 62cc chamber. The hollow-stem intake valves and sodium-filled exhaust valves are incorporated to reduce mass which allows for better valve control at higher rpm." |
