Adding Steering Wheel Controls
HAS ANYONE TRIED TO INSTALL RADIO CONTROLS ON A 1LT OR A C6 THAT DID NOT COME WITH THEM? I HAVE AN 08 AND WOULD LIKE TO TRY THE INSTALL IF IT IS POSSIBLE. :thumbs:
Called dealer close to me 2 days ago about the necessary parts, and he stated that it was an entire steering wheel assembly. I too want the radio controls and have no gripe turning a few screws to do so, but not willing to buy an entire steering wheel just to do it.
Have you called the dealer to see if this is a plug and play piece or is it the steering wheel assembly? |
I am also very interested in this mod. Has anyone performed this?
i have seen the schematic and it looks like the switch fit in any 07 or 08 steering wheel but i am not sure. i will get this to work on my car i just dont know how long or how much it will cost to do it. i would also like the telescoping wheel feature that will be my next project, but if your right about the buying the whole assembly i might knock out two birds with a single (could be expensive) - stone!:D
How much was the entire steering wheel?
You don't need the whole steering wheel.
I found a link to an HHR site where a guy had done the deed and supplied these part #'s. The HHR wheel looks the same as ours. I haven't confirmed that these exact #'s will work, but my research has shown that the parts for our car are available seperately and these #'s below are listed as 07-08 part #'s The question is, is the harness from the column to the radio in the car already, it was for the HHR, so ........ Switch $34.14 15842365 Harness $14.81 15234343 Module/Cover $18.85 15234337 |
I am interested in the wheel controlls but i have an 06 c6 3lt
Cool. I bet you will be able to do it for bluetooth as well.
:bigears
Originally Posted by danl72
(Post 1566182675)
Originally Posted by glenB
(Post 1566180048)
I found a link to an HHR site where a guy had done the deed and supplied these part #'s. The HHR wheel looks the same as ours. I haven't confirmed that these exact #'s will work, but my research has shown that the parts for our car are available seperately and these #'s below are listed as 07-08 part #'s The question is, is the harness from the column to the radio in the car already, it was for the HHR, so ........ Switch $34.14 15842365 Harness $14.81 15234343 Module/Cover $18.85 15234337 Has this been confirmed? |
I'm very interested in this subject, too. :bigears
Dan |
Anyone? I did on search on the subject but just became more confused. :confused:
Gene Culley's Prices: Collision Catalog - Chevrolet Steering wheel and trim - Radio control Radio control 2006 - 2008 $33.07 Collision Catalog - Chevrolet/Geo Steering wheel and trim - Switch cover - Passenger side W/radio control Right 2006 - 2008 $18.27 OEM Catalog HARNESS $14.35 Total:$65.69 I just need to know if it will work. |
Originally Posted by nearwater
(Post 1567242518)
Dan |
Originally Posted by Swiftrider08
(Post 1566190908)
Nope! GM has already said it would be way to cost prohibitive to do bluetooth on the older cars.
TTT - Anyone on the SWC's. I have a 2006 and need to know if the connectors will work with the NAV unit. I don't like switching from NAV to change radio stations.
Ttt
*BUMP*
I am also interested in the original question. I have no interest in the bluetooth part that someone else asked about. |
Originally Posted by dkrhardy
(Post 1567301358)
*BUMP*
Originally Posted by gibear2k5
(Post 1567342976)
I can feel it, any day now someone knowledgeable is going to answer this question. :toetap:
The radio will not make use of the new switch inputs until it’s reconfigured. The base U66 option with a Delco amplifier will not work. The premium U65 using a Bose amp will work. Using a Tech2 I had to change the option configuration in the radio from the U66 to the U65 and then the switches worked. I don’t know what issues there could be from telling the radio it’s using a Bose amp when it’s actually a Delco? But everything seems to work ok. I have a feeling some of the difference is with the EQ settings. I know Bose likes to use their own presets programmed into their amps. Now I just need to decide if I want to spend the $$$ on a new steering wheel… :ack: |
