running c6 autocross without wheel sensors?
I find that I need to use my 2007 daily driver (coupe) this weekend for an autocross. It definitely will not be the 2004 z06 but...I want to run.
Here is the deal. If I put my z06 18x10.5's Hoosiers on the c6 coupe, what is going to happen without tire sensors? will the car go into limp mode on me? if it will go into limp mode, can I bypass this easily for one event? :willy: Elizabeth |
Originally Posted by eaa1964
(Post 1566224668)
Here is the deal. If I put my z06 18x10.5's Hoosiers on the c6 coupe, what is going to happen without tire sensors? will the car go into limp mode on me? if it will go into limp mode, can I bypass this easily for one event? :willy: Elizabeth Your C6 may not be the dissapointment that you are thinking it may be compared to your C5Z06. ;) --Dan |
thanks for the info. but it will disaapoint...it is an automatic...and my z06 is a danny popp special. 2007 coupe is strictly stock including alignment. however, since z06 is broken, coupe will have to do...afterall, it is about the fun!!!!
Elizabeth:cheers: |
(Post 1566226790)
Elizabeth:cheers: --Dan |
you'll have to turn off AH/TC. with the sensors mission you can't put the car in comp. driving mode.
(Post 1566224668)
Here is the deal. If I put my z06 18x10.5's Hoosiers on the c6 coupe, what is going to happen without tire sensors? will the car go into limp mode on me? if it will go into limp mode, can I bypass this easily for one event? :willy: Elizabeth My experience has been that if you change out a couple of wheels, such as leave your street tire with sensors on the front and put on a set of Drag Radials on the rear with no sensors, then when you start driving faster than 20 mph the TPMS computer gets signals from the front sensors and is expecting to have the rear sensors send a signal. When the rear sensors don't send their data to the TPMS computer, within a minute or two of beginning to drive you'll get a message of defective sensors, a "Service Tire Monitor" message, and probably "Limit Speed to 55". HOWEVER.....if you have NO sensors, when you start driving the system waits "approximately one hour" (according to the owner's manual) before deciding that you have a TPMS problem rather than a sensor problem. That's one ignition cycle - one hour of steady driving without turning off the ignition. After approximately one hour of driving with no sensors you'll get a "Service Tire Monitor" message and probably the limp-mode message "Limit Speed to 55". If you have no sensors and are running in Comp mode or with AH completely off, after an hour of steady driving when you get the "Service Tire Monitor" message, the AH will automatically turn "ON". You can pull over, shut down the car, restart, clear any DIC messages, and you'll be able to again go into Comp mode or turn AH off for another hour. So.....If you have no sensors at all, for Auto-x you should not have a problem going into Comp mode or turning AH off. At least that's my experience and knowledge of the system, YMMV! Have fun running the C6. Like others have said, I think you'll be surprised how well a stock A6 car will do! Bob :flag: |
