Anti-Lock Brake Problem
The other day, my anti-lock light came on and I have no idea why. The brakes feel fine. Anyone have this happen or know anything about it? Its a stock 87 with the 4+3.
Could be one of the following: abs computer, wheel sensor, abs relays, wiring problem, low fluid, etc. ABS parts are fun to track down. IF you can find an old tech with an ABS diagnostic tool - you're golden. Helms manual and or supplemental ABS troubleshooter guide will help
Call all the local Chevy dealers and see if they still have a C4 ABS tester, it will find the reason your abs light is on!
I had the same problem in the past. I added some brake fluid and the problem gone...
-Beppe- |
Anti Lock Brake
My left rear wheel sensor was damaged when the rear wheel bearing went bad. I replaced the sensor and the system was back up. My sensor had worn through on the end. It was obvious when I compared it to a good sensor.
Larry |
Originally Posted by jfb
(Post 1566308124)
