Has anyone had this happen?????
Today while approaching a stop sign my car died. Would not start back. After 20 mins started but wouldn't stay running, very bad idle. Paid $50 to tow it 4 miles back home. Had youngest son sit in it and turn key on and the fans kept coming on and relays clicking and fan would cut off and everything but no start. I found 2 plugs on the low pressure A/C sensors with wires touching just enough to do this. Seperated wires and car started right up and runs like a dream......Why would this do this? Do these short out the electrical system? I am at a lose here.....Thanks for any input!
I'm not an electrical guy at all, but I do know this...TPI doesn't like low voltage at all....ask me how I know...:toetap:
Well it just did it again. After leaving key on for a few mins everything starts running as normal and it will start again. I have a 1993 LT1....what is the relay in the passanger front fender well on the back side? It clicks a lot when this is happening?
You may want to ohm your injectors
Originally Posted by cwyates4
(Post 1566412229)
Here ya go:
http://forums.corvetteforum.com/show....php?t=2055839 Make sure you check them cold and check them hot. |
Is your SES light on?
Originally Posted by slicked25
(Post 1566416091)
(Post 1566415725)
Here ya go:
might want to check your fuel pressure. same thing happen to me tow job and all .had no fuel pressure
