Share your experience please
How do I find out what equipment, engine and options my car came off the line with. I've found how to chweck paint, trim and engine #'s but but what tells me what it came with? Thanks for helping!
What year are you talking about? The word "trim" in your post suggests a 63-67?
For the most part, all you can do is use detective work to see what things are in place, what evidence there is that other things were in place. Use the tachometer or other gauges to help determine what horsepower those gauges were for, and then if you are lucky and those gauges have a ink-stamped date code that closely aligns with the production date of your car, you have a high probability that those gauges are original to your car and actually tell you something about - your car. |
Thanks for the help.
Deleted due to inaccurate content.
My 66 coupe shows all the signs that it was a big block high horsepower car. The gauges seem to be original as I had the dash out not long ago and it all seems to match. My battery is located on the Passenger side though?
Originally Posted by Fast66vette
(Post 1566550817)
Originally Posted by Shurshot
(Post 1566551023)
Nothing wrong with that :thumbs:
Originally Posted by 62Jeff
(Post 1566551038)
I thought big block batteries were on the driver's side? Am I getting confused?
I'm pretty sure that batteries were on the driver's side for all big blocks and all small blocks with AC.
66 C60?
(Post 1566551808)
66 C60?
please straighten me out. my 66 has AC and big block in it, how do I verify it came with a BB. TX
A 66 BB with air will have a low red line tach and a 2 bolt 427 hydraulic cam engine with a Rochester 4 bore carb. Probably also have a cast iron intake...:thumbs:
only a 65 L78, and any car with A/C had the battery the driver's side.
(Post 1566553286)
Originally Posted by a560156
(Post 1566554631)
Umm...didn't I already respond with that?:willy:
(Post 1566555336)
you might have but too many other people are confusing there self:willy:
(Post 1566556035)
Yep, I was one of those for sure. By the way, did you figure out what was wrong with your power window post? Hint - double negatives
(Post 1566556546)
yeah but I was never that good with english. If you did not know by now:willy:
