Where is the fuse for the rearview mirror
I was hooking up a homelink transmitter into my visor, but when I checked power at the pig tail the circuit is dead. My interior lights in the mirror wont come on either so I am assuming its on the same fuse.
What fuse powers the rearview mirror? |
ttt
It's one of the fuses in the passenger side footwell fuse block. I know it's a 10 amp - and I believe it's #6.
check em all....gotta be one of em.
. :cheers: |
There are 2 functions on the rear view mirror fused through different circuits
The floods that are on permanently are fused through fuse #21 (10A). The switchable lights are fused through #2 (10A) (monitored load). The latter fuse affects other functions such as the vanity mirrors, the underhood lamp and the IP Compartment Lamp. If those are out as well, there's your problem. Both are on the IP Fuse Board in the footwell. Relay 37 is also in play in the circuit. |
Good informatin on the fuse location for the r/v mirror.
My fuse was blown (#21 in the footwell) replaced and all is good. Thank you for this forum!:rock: |
Originally Posted by blacksedan87
(Post 1566818378)
Saved this info for later use. Thanks for those that posted the info.
02 vert r v mirror
Originally Posted by Kehraus
(Post 1578558815)
My fuse was blown (#21 in the footwell) replaced and all is good. Thank you for this forum!:rock: Read on in Corvette Forum and what a novel idea Fuses! check the fuse 2 fuses. Fuse #6 was burnt. Thanks again Merry Christmas and Happy Holiday to every contributor on Corvette Forum. |
Originally Posted by webdzynes
(Post 1605293949)
Does anyone have a schematic for the fuse numbers for the footwell fusebox? (there are several for the fusebox under the hood, but not for the interior one) There are references to fuse numbers for the footwell but I cannot find any diagram showing which fuse is what number...
Which fuse is #21 & which fuse is #6?? |
(Post 1605300763)
Thanks, but no. Its the footwell fusebox and the diagram is on the panel cover but has no numbers and only the 4-letter title specifics for each fuse.
The windshield mirror operates off of 2 separate fuses (possibly #6 and #21) - or so I am told. 1 fuse controls the plug-in wire cluster (into the back of the mirror) and the other fuse controls the secured closed line running from the mirror support into the mirror itself. I need the fuse (location) that operates the plug-in wire cluster. That's where I was pulling the radar's detectors' power from... It's not the CTSY/Lamp fuse evidently... Thanx https://cimg0.ibsrv.net/gimg/www.cor...693df9c62c.jpg |
