ABS and traction control system?
I started my car this morning after a few min. ABS and traction control system light came only for no reason? I then drove to work about 15 min. turned off and start again...it's gone. Anyone have this problem before and what should i need to be awear of? Thanks!
Re: ABS and traction control system? (00c5coupe)
I get the same problem on mine, comes and goes, I checked the codes, they were lack of communication codes. BTW, did you change your brakes before you got the codes? Mine started after I had the brakes redone and added SS brake lines
Ira |
Re: ABS and traction control system? (3rdtoy)
no, i didn't get any brakes work...they're still a good condition.
Hey Now:
If you pull the codes and get a 1288 code, I know the problem. :lol: |
Re: ABS and traction control system? (barryscott)
Barryscott,did you get the recalibration done on yours yet???
Re: ABS and traction control system? (C-5 TECH)
[QUOTE]Barryscott,did you get the recalibration done on yours yet???
Hey Now: Yes, did get the recalibration done a few days ago. So far no more problems or codes!! :lol: Thanks again for your time and knowledge. :cheers: |
Hey Now: If you pull the codes and get a 1288 code, I know the problem. :lol: NO, not 1228. It's 1225 (RF Excessive Wheel Speed Variation). That's weird why it happened right after i just backup the car. Do I need to pay attendtion to something? [Modified by 00c5coupe, 1:38 AM 1/6/2002] |
Faulty front sensor jumper harnesses are common...Left and right harnesses are the same...The best way to diagnose is to swap the harnesses,then if you get a L/F ABS code,you know that you have a faulty harness :yesnod:
