CCw Wheels with Z06 tires
Does anyone have CCW Wheels 18 x 9.5 and 19 x 11 with Z06 tires on a standard C6?
Thanks! |
CCW's
I have the SP500 in black
19x13 REAR and 18x9.5 FRONT |
That's a very common wheel size for C6's. CCW makes BUNCH of wheels in that size.
You can actually go to 18X11 or 11.5 in the front on the C6. Ask Mike (Bowmanized), as he has 18X11.5s and 18X13s on his C6.
San |
I have CCW 505's in 18x9.5 and 19x11 on mine. They look great! You can check out pics of mine if you open my profile, go to threads Ive started and about two threads down in my Z06 brakes. Sorry, I dont know how to do pics:o
Originally Posted by oldmansan
(Post 1567013833)
San |
Thanks for the feedback!
I have the 505s (18x9.5/19x11 with ZO6 tires) they're even with the edge of the fender.
http://i108.photobucket.com/albums/n...s/Image035.jpg I recently added ZO6 (stock) splashguards to the rear...looks much better IMHO. http://i108.photobucket.com/albums/n...s/Image033.jpg http://i108.photobucket.com/albums/n...s/Image030.jpg |
I have the CCW C14s with the Z06 tire set up, no rubbing and nothing sticks out past the fenders.:cheers:
Originally Posted by 1BDRSK
(Post 1567017752)
Thanks to all that responded. |
If you pm me your email address I can shoot you a picture also, just lemme know =)
Thanks Chris |
Originally Posted by NYC6
(Post 1567015745)
You cant do those size wheels without it sticking out a ton or doing a widebody.
Originally Posted by Zteve
(Post 1567030043)
I have CCW 18x11" in the back with 305/35/18's and they don't stick out or rub one bit. CCW did their homework and got the offsets perfect.
(Post 1567015724)
(Post 1567032613)
You need to reread the post I quoted. He said you can mount a 18x11 or 11 1/2 IN THE FRONT! You cannot run that size wheel in the front or a 13" in the back without a widebody. Which I clearly stated. I also said I run 325/275 on my CCW's without sticking out.
(Post 1567015745)
http://forums.corvetteforum.com/c6-t...re-setups.html San |
My street wheels are CCW SP16A wheels, 9.5” x 18” front / 11” x 19” rear with Goodyear Eagle F1 Supercar EMT’s...275/35ZR18 front / 325/30ZR19 rear...stock Z06 tires. The rear tires stickout just slightly...not enough to worry about. This setup works quite well...no adverse issues at all. If you ever plan on going to a big brake setup talk with John first...the space necessary to go to big brakes is very limited in the rear. CCW makes a quality wheel and John is a true wheel expert. They're a first rate company to do business with.
http://i62.photobucket.com/albums/h9...tire_comps.jpg http://i62.photobucket.com/albums/h9...tire_car_1.jpg
(Post 1567013833)
San If Mike is running 13" rims on the rear he likely has Z06 body panels or he's tubbed his wheel wells (or his rear tires really stickout). :) |
Mike has the Z06 rear fenders for the 18 X 13 rears. You can see pics in the thread I referenced above.
San |
