seat bladders
i have a 98 vert with the sport seats...
can i take out the passenger bladder and put it into my driver's side since my driver's side lower back support is leaking...? i dont really care if i have a leaking bladder in the passenger side since people rarely care to adjust the seat on that side anyway |
Take the bladder out, get a rubber raft repair kit, and patch the bladder. Simple fix. :thumbs::cheers:
i was thinking of doing that too after doing some research, but i wanted to see other options...
sometimes it's just the hose connecting to the bladder that leaking. They tend to dry up.
do i have to remove the entire seat to have access to this or can the leather covers unzip and come off?
Originally Posted by ferrari red vette
(Post 1567520337)
i gotta take the seats out since they are moving a 1/4" back and forth anyway.. but cant find the DIY fix ive seen before...anyone?
The bladders are not difficult to fix. There's a plastic tube that routes from the motors that takes the air to the plastic bladder. It routes around the seat but it has plastic elbow connectors to get around some tight corners. Most guys seem to find that it's not the bladder thats punctured but the connector thats broken. A replacement is a few $$.
You can check out the problem with the seat in place by just unzipping the seat back. Mind you, it's a five minute job to get the seat out and it'd make it much easier to work on the problem, once you find it. This is the best link and it has some pics to let you see the components: http://www.vetteessentials.com/instr...er_change.html Changing the seats out would mean moving the control panel to the other side and refitting the trim pieces. never tried it but I doubt it would be simple. I'd try a repair first. To answer your other question, here's a link for a fix for the rocking seats: http://www.lieblweb.com/TechLinks/Co.../C5SeatFix.htm HTH |
I fill up my bladder on my drivers side then a few seconds later it deflates. you guys think this a problem with the pump or is it the tubes? And like this original question, is it possible to just take the passenger side setup that works good and put it in the drivers side?
Originally Posted by Dolis2000
(Post 1567522052)
:thumbs::cheers: |
So is it possible to just but the airbladder section? I bought an extra set of seats and they are shot on both sides.
http://img.photobucket.com/albums/v6...e/DSC04592.jpg http://img.photobucket.com/albums/v6...e/DSC04594.jpg |
Originally Posted by DRKCYDE
(Post 1567524754)
Originally Posted by DeeGee
(Post 1567526367)
That looks like you need a new bladder to me:thumbs:
