Steel cap for Dana 44
Did you find it or make it? The last pic of it shows it hasn't even been drilled yet for bolt holes.
Originally Posted by Durango_Boy
(Post 1567682368)
i like it !!! and would consider using it .
NICE PIECE! I was alway afraid of the aluminum caps splitting while watching late model Vettes launch at the drags.
Originally Posted by Solid LT1
(Post 1567693317)
Here's the cap mounted
http://i85.photobucket.com/albums/k4...forum/Bob7.jpg |
What are the benefits of caps like that? Street use, track use...maybe only for high HP engines and very stout drive trains?
Look at the second pic Stinger posted. The cap breaks where it has been cut down for the bolt. Also the cap supports the lateral forces of the carrier. The steel cap is wider using the the case for additional support like the iron diffs.
The stock caps have been known to break just from spirited driving with a stock motor and driveline. Since there are no new caps available, and they have to be machined in the case so a used cap won't help, the only option was to buy another diff and have it rebuilt or do the full conversion and install and iron diff. This cap allows a diff with a broken cap to be repaired and it eliminates the weakest parts of the 80-82 danas. Mike |
I guess I never really took into consideration how big that cap really was. Now that I can see it mounted, that thing is just monstrous!
Nice machine work. What type of steel did you use for the cap?
