New calipers, bled brakes, no pressure?
I need some help!! I replaced my calipers with some powdercoated ones. Bled each one about six times using the old fashioned method. Had a solid pedal with the car off, but when I start it, the pedal goes to the floor. I then tried a hand vaccuum pump and bled each one about 3 more times. Same results. I don't see any leaks from any fittings. I'm baffled. Any one have any ideas? Is it possible there could still be air in there?
Did you let air into the master cylinder? If so you need to bleed it.
San |
I may have let air in the master cylinder. Level was pretty low after I changed the calipers. I'll try that.
Buy yourself some brake line plugs to prevent that from happening next time. They're cheap, a few bucks at most.
San |
Thanks for the advice! :thumbs:
Try and bleed the brakes again to make sure there is no air in the system.
Originally Posted by danl72
(Post 1567779873)
San |
some calipers must be bled in a certain position or they trap air. Not sure if this is the case with yours, but for those that require a certain position the can not be mounted.
Are your calipers on upside down? Are the bleed screws facing up or down?
If you got air past the master cylinder then you are going to have to have the car flatbedded to a dealer that can purge the ABS system to get the air out. With all that you've done it sounds like that's what you've got to do. Without that special equipment you just can't do it like conventional brakes. Letting the reservoir go empty sounds like the problem.
Originally Posted by C6400hp
(Post 1567781189)
Douglas in Green Bay :D |
Originally Posted by Walt White Coupe
(Post 1567781845)
Originally Posted by cranky
(Post 1567783969)
:iagree::iagree: next time, do one caliper at a time and bleed each one. have done over 15 sets of these and not one problem. if you do not have the scan tool to electronically work the abs system, you will never get a pedal on it. good luck :thumbs:
Not really easy but it can be done When ever you bleed your brakes make sure you have a full MC with fresh brake fluid. Use a Motive power bleeder to push the brake fluid though the lines. 15-20 psi will do it. Open and CLOSE the bleed valves on the caliper while the fluid is flowing. If your still getting soft peddle, look at a few things; tapered brake pads bent caliper other things to do start the car up and let the ABS cycle on, pump the brake peddle a few times. Turn car off bleed the rear brakes, then pump the brake peddle 3,4, 5 times refill the MC, and do the front brakes, then pump the brake peddle 3,4 5 times YES the car is on four jack stands, all the wheels must be off. If this does not do it, then put the wheels back on and go for a very very slow drive down your street. Your pump your brake peddle severl times. This cycles your ABS. Your brakes may not work well, so drive very very slow. put car back into garage and back up on jack stands and rebleed the brake calipers. again make sure the MC does not go dry. This does take some time, but works very well I know there should be a specific order to bleed calipers, but I do my rear two then front two calipers. Never had a problem. Done many other guys vettes the same way, No problems. Good Luck |
(Post 1567781189)
Thanks for everyones advice!! |
Originally Posted by omigosh
(Post 1567784797)
Yeah, I'm a bonehead! Thats what it was. After looking at the service manual about 15 times, I noticed the pic in the book was backward from mine. Boy do I feel stupid!!!
(Post 1567784797)
(Post 1567784797)
(Post 1567786973)
No worries, I have read several stories from guys here that a dealer technician made the same mistake on their cars. Happens alot for some reason. Are they working well for you now? Glad I could help.:thumbs::cheers:
I switched to ceramic pads too, so hopefully I will actually be able to see my wheels and the new calipers!! |
I was going to suggest the backwards calipers as its fairly common. I might need to start labelling them, I've just been afraid that I might mislabel a pair one time and cause someone a problem.
Originally Posted by corvette pilot
(Post 1567793864)
