BendPak HD-9 Four Post Lift Installed - Pics
I've had a BendPak scissor lift (MD-6XP) for a couple of years and have been very pleased with its versatility.
Since winter is coming, and my garage is filling up with snowmobiles, I thought it would be a perfect time to 'justify' buying a 4 post lift to stack my Z06 and my Camaro for the off-season. The lift is a BendPak HD-9 (the wider of their current options). Rough dimensions are 121" wide (outside to outside) and about 174" long (excluding the ramps). I contemplated buying their 'ST' version that is about 103" wide, but that version wasn't wide enough between the crossbeam supports to fit the 76" (tire) width of my Z06. Close, but no cigar. I bought a 110v for versatility - I'm planning to have a winter layout and a summer layout for the garage. FWIW, a 220v is also available and is supposed to raise the car faster. IMO, the 110v is plenty fast, raising my Z to the top safety lock in about 55 seconds. Max lift height is 70" which gives you about 78" to the bottom of the car (5" for the ramp height and 3" or so of normal ground clearance). My ceiling height is 121". The pic below shows the Camaro and the Corvette on the 2nd to the highest safety stop - it could go up another 5" or so, but the hood of the Camaro would hit the garage door. The included ramps work fine for my '69 and my truck, but due to the low ground clearance of the Z, I ended up using the wood ramp ends I built for my scissor lift to help get the spoiler over the main crossbar. (See pic below). I considered other brands - Backyard Buddy, Rotary, Revolution (Rotary), and Direct Lift. In the end, the combination of price (about $3500 installed, including casters which allow one to move the lift around), reputation of brand, (auto) air safety locks, enclosed cabling, adjustable ramp width (between 37.25" and 44" inside to inside), and optional rolling bridge jack made the BendPak HD-9 the best option for me. (plus, the blue matches my other lift ) BendPak HD-9 web page: http://bendpak.com/products/automoti...lifts/hd-9.php Bought it locally (Shakopee, MN) from a company called Benco (no affiliation with BendPak). They made their lives easy by bringing a truck with an on-board hoist.. Would be difficult to get the larger sections off the truck without some type of lift (engine lift would work). 2 guys took about 3.5 hours to set it up. The install was fairly basic really, but IMO, only 'easy' after watching someone do it. It would have taken me a lot longer. Thanks to the CF guys who inspired/helped me - Patches, CAPTEJ, etc. :thumbs: Here are some pics of the Z on/under: http://i93.photobucket.com/albums/l5...PostLift64.jpg http://i93.photobucket.com/albums/l5...PostLift56.jpg http://i93.photobucket.com/albums/l5...PostLift80.jpg http://i93.photobucket.com/albums/l5...PostLift70.jpg Overall, very happy with it - should have bought it a long time ago. :) |
Am I understanding this right, you don't have to bolt it into the concrete? If not, I'm a happy guy. The only reason I'd not considered a full sized lift is that I'm not sure how long I'll be in this house, and really don't want to bolt one down.
I have the same lift and you do NOT have to bolt it down.Mine works just fine unbolted.
nice, notice you need 9-6 inches of clear for opener
wont fit in less make sure you measure b4 you buy |
What is the ceiling height you need for these?
Chris -
Now that you know how to install one - come over and help me do mine. I have two 4 post and a 2 post waiting to be put up. Eric |
told you brother....i love mine..ej
Originally Posted by painexpert
(Post 1567780292)
Originally Posted by blznsdl
(Post 1567780322)
Originally Posted by SpeedshifterZ06
(Post 1567780642)
Here's a good tool: http://revolutionlifts.com/Ceiling.asp
Originally Posted by AtomicZ
(Post 1567782047)
Chris -
Originally Posted by captej
(Post 1567782110)
:cool:
wait a sec...the lift is not bolted to the concrete floor??? how is this safe?
Originally Posted by nzk
(Post 1567782623)
I sure am happy you posted about this lift. I was sure I'd have to bolt a 4 post down. To me, the extra $1,500 (installed for a HD9) is chump change more than the MD6. What am I missing here? This is great.
The lift is nice; now if you just had that old Camaro out of the way. I'll take it off your hands.:D
:thumbs: WOW :cheers: wish I had one ! Very Nice :flag:
I wonder why the Bend Pak is a grand more than Benco's other model. I got a black four post lift from them with all the extras as you did. I also had it installed but my total cost was 2500 installed. I wonder what the difference is, I had mine installed back in September. I guess it does not matter to either one of us but others may want to know. Absolutely no need to bolt down the post, these things are not going anywhere.:cheers:
Originally Posted by SidePipeMusic
(Post 1567783664)
The big difference between the scissor and the 4 post is the scissor gets the wheels off the ground - important if you change them a lot or do brake work. The downside to the scissor is it doesn't have 'total' under-car access - important if you're changing torque tubes ;) For now, I'm planning to keep my scissor lift - I change to winter wheels on 3 vehicles, so the scissor lift is easier. In fact, the scissor lift will fit between the ramps of my 4 post. Next summer, I may sell the scissor and get two of the rolling bridge jacks like captej has - they aren't cheap however at about $1400 ea. |
Originally Posted by camiv
(Post 1567784542)
A few things I noticed about the BendPak vs the Direct Lift:
Since this is a one-time buy for me, I weighed safety (or at least the perception of safety) over $$. Also swaying my decision was the BendPak brand - their reputation for quality and service seems consistent. As you said, they are both very good lifts.. There is no question that Direct is getting more competitive and trying to take some market share from manufacturers such as BendPak, Rotary, etc. Can't go wrong with either :thumbs: |
Originally Posted by carcrazyandbroke
(Post 1567784235)
Originally Posted by HIRISC
(Post 1567784785)
I think you can still get the MD-6XP scissor lift for about $1800 shipped. That's about 1/2 of the cost of the HD9.
LIft
Looks like a nice install. Had the same lift installed several weeks ago. And yes no need to bolt down. My installer said he installed these on dirt, self levelling to a point. Noticed that your ramps hang kind of low, so it looks like you remove them which is probably a pain. Mine have aluminum spacers under them and only hang down 3". Also added a high lift kit to the garage tracks and a Jackshaft opener. This brings the door almost to the ceiling. Just some thoughts.
Ken:cheers: |
