Need a KO locking pin
I lost the cap and the locking pin from one of my repro KO's on my 66 Corvette. Have ordered a replacement cap but can't find where I can get the KO locking pin (not sure if that's the correct name for the part). It's the 1 inch pin that locks in the KO and keeps it from pinning off. Can anyone tell me where I can get one????
I think it's just a small diameter aluminum rod. Try a hardware store, cut down to proper length.
I believe that most of the repro knock-offs come from Corvette America.
Think that this is what you are looking for: http://corvetteamerica.com/cf/displa...name=Knock-Off Anti-Theft Pin.&image=/images/catalog/products/item_1618.jpg |
If you have a local hardware store like an Ace hardware with small parts bins you can buy a steel roll pin that fits.
Brian |
if you can not find one I think that I have one in my tool box.You can have it if you need it
Corvette Central sells them. Part #642319 for a set of four wheel spinner lock pins for $8.95. :thumbs::thumbs:
Originally Posted by Allcoupedup
(Post 1568178485)
Brian |
I use allen head screw in mine.
When you put them in add a little grease to them first....... that way they will not tend to fall out :thumbs:
Doug |
I had bought a set of the aluminum repro pins and was unable to fit the pins in the openings, even after I tapered the ends. So I just whacked the spinner with the Mutha Thumper and got it to move a few more degrees. That makes me feel more confident than any roll pin ! (and hey, I know that they are just to discourage theft).
Two cars with KO's. Never used the pins. Probably won't, either. Maybe in my next life.:D
You can suit yourself. |
Originally Posted by speedyc5
(Post 1568180047)
larry |
Originally Posted by redred65cpe
(Post 1568202886)
Wow. I spend about that much for about 25 feet of aluminum rod from a welding supply store about 10 years ago. Still have a bunch left.
larry |
