What's the best way to cut exhaust pipes?????
I don't posses any fancy tools, but I am going to begin to install my headers tonight. I will need to cut both of my exhaust pipes so that I can install the reducer that will mount up to my Hooker Headers. What are some of your guys or gals recommendation as for saws, TNT etc. Thanks in advance for any ideas :) :) :)
Re: What's the best way to cut exhaust pipes????? (Warp70)
A reciprocating saw or what's commonly known as a sawall.
I was just cheap and used a hacksaw. Got it all off. Have also used a dremel as well.
-terry |
Re: What's the best way to cut exhaust pipes????? (terryrudy)
After you cut your front exahaust pipe, will it line up with your headers?? You may be better off saving your front sections and having new pipes made that will fit on your headers. I have 2 sets of front pipes, but I didnt plan it that way! :) MJ
Re: What's the best way to cut exhaust pipes????? (Paul 75 L82)
A reciprocating saw or what's commonly known as a sawall. |
Re: What's the best way to cut exhaust pipes????? (Anar76)
A regular pipe cutter(plier handles with chain and cutting wheels) is not that expensive, and is very user friendly under the car.
Well worth the money in my booK. Good Luck, TJ |
Re: What's the best way to cut exhaust pipes????? (MNJack)
You may be better off saving your front sections and having new pipes made that will fit on your headers. |
I vote for the Sawzall. It's a beautiful thing! :yesnod:
Re: What's the best way to cut exhaust pipes????? (78Vette-SA)
Well if you can cut your pipe away from your car I vote on using a Bandsaw :cool:
I agree on a bandsaw or chain cutter but if forced to use a hacksaw and want a straight cut buy two cheap muffler clamps bolt 1 on each side of cut and use flat side of clamp as guide .Rotate when cuts progress .Sounds goofy but works.
