Ipod Adapter - Install Procedure - Z06/C5 - No CD Changer
Guys:
I also have these pics and procedures uploaded to my web site at the bottom. http://mysite.verizon.net/res0aae8/webpage.html I got a Ipod adapter for xmas... :thumbs: I got: 1.) Peripheral ISGM73 iPod™ Adapter 2.) Peripheral GMH20TC 20-Pin T-Harness for 1997-04 Corvettes First off the procedure that came with the adapter sucked ! I had a bunch of wires and no clue which was which. I looked over the net and eventually made heads or tails out of it. Once I did that it was very straight forward. Hopefully this can help clear it up for you guys so as to take the leg work out of it for you. Set the White Peripheral box so that Dip Switches 3 and 8 are set to "ON". You can see in the below pics that only GMH20TC, and PXHGM1 are used. PXHGM2 and PXHGM3 are not used at all. PXHGM2 and PXHGM3 come with the Peripheral ISGM73 iPod™ Adapter package. The white connector just above the white Peripheral box in the below pic is not connected to anything that I could find...:crazy: I just taped it up. http://mysite.verizon.net/res0aae8/ipod/ipod01.jpg http://mysite.verizon.net/res0aae8/ipod/ipod02.jpg http://mysite.verizon.net/res0aae8/ipod/ipod03.jpg http://mysite.verizon.net/res0aae8/ipod/ipod04.jpg http://mysite.verizon.net/res0aae8/ipod/ipod05.jpg http://mysite.verizon.net/res0aae8/ipod/ipod06.jpg Remove the 2x screws holding in the factory deck, and the 2x screws holding in the AC unit. Its easier just moving the AC unit to the side when doing the install. http://mysite.verizon.net/res0aae8/ipod/ipod07.jpg http://mysite.verizon.net/res0aae8/ipod/ipod08.jpg http://mysite.verizon.net/res0aae8/ipod/ipod09.jpg http://mysite.verizon.net/res0aae8/ipod/ipod10.jpg I wired everything up loose just to test it to make sure it all worked correctly. I then re-routed all my cables in the pics further down. http://mysite.verizon.net/res0aae8/ipod/ipod11.jpg Route your wires behind the deck and behind the AC unit so that you can re-install both components without the cable being in the way http://mysite.verizon.net/res0aae8/ipod/ipod12.jpg I put double sided 3M sticky tape on my Peripheral box and mounted is on top of the little box back in there (see next couple pics) http://mysite.verizon.net/res0aae8/ipod/ipod13.jpg http://mysite.verizon.net/res0aae8/ipod/ipod14.jpg Run the single Ipod cable along the exhisting factory cable and tie wrap it. http://mysite.verizon.net/res0aae8/ipod/ipod15.jpg Reverse the procedure to re-install the consoles. Its completely invisable when the center console is closed. No one will know whats in there ! http://mysite.verizon.net/res0aae8/ipod/ipod16.jpg Its now up to you where you want to mount the IPOD. I mounted mine to the underside of the center console as seen below with some double sided sticky tape. http://mysite.verizon.net/res0aae8/ipod/ipod17.jpg http://mysite.verizon.net/res0aae8/ipod/ipod18.jpg Hope this helps take the frustration out of doing this install. As I said before... there is no real procedure out there that I could find to install this. Toque |
Originally Posted by Toque
(Post 1568528301)
Guys:
Originally Posted by Choreo
(Post 1568528743)
Great write-up! Getting ready to do this install myself as soon as I can figure out how to defeat the battery drain issue when the car is turned off.
I have been unplugging mine when I get out of the car. Its not a daily driver so I'ts no issue for me. Thats not a good solution though really. :lol: Toque |
(Post 1568529164)
Thanks !
Sweet install Mark:thumbs: I'll be saving this post for future reference;)
How timely. Just got my Neo IPOD2CAR setup and Peripheral cable in the mail today. Your write-up and pics will come in handy. You are the man. :cheers:
Not sure how this unit powers up, but there is a couple of wires in the passenger footwell that are hot only when the ignition is on (i think it is orange).
The one thing I might have changed is take out the aux power in the glove box and run the cable in through there. If you undo the connector you need to turn it 90° and pull then another 90 and it will come out. Just a suggestion. |
(Post 1568529289)
Yes, but the problem as reported in other posts is that the Peripheral Adapter still draws current ALL THE TIME with the car turned off as there is still power to the radio harness (as evidenced by the CD ejection working even with the car off).
Originally Posted by jim02C5
(Post 1568529427)
Originally Posted by SUPERCRUZ
(Post 1568529998)
Toque |
(Post 1568529289)
Peripheral just confirmed in an email to me that the unit draws a little bit of current at all times, even when vehicle is shut off and no iPod is connected. |
Originally Posted by Aerohawk
(Post 1568537136)
(Post 1568537136)
As reported in the post I started, I'm already out another $100 as a result of having to replace my car battery after this thing drained it 4 times (twice without the iPod plugged in). This was due at first to me not figuring out what was happening and then to my forgeting to be sure to drive the car every few days to avoid the depletion.
Peripheral just confirmed in an email to me that the unit draws a little bit of current at all times, even when vehicle is shut off and no iPod is connected. On numerous occasions I have left my Ipod to charge in my car over the weekend and still can fire it up Monday morning without problems....
(Post 1568538614)
Damm....:(
Great pictures! I may actually do it now.
How about some pictures of how you control the iPod via the deck? |
Very nice writeup. Thanks for taking the time to document and post up the details.
Originally Posted by BUBBAS 01Z06
(Post 1568539318)
This seems to be different for every car...I have the same install and have gone up to 3 weeks without starting my car and have had zero issues with battery drainage....
On numerous occasions I have left my Ipod to charge in my car over the weekend and still can fire it up Monday morning without problems.... You'll be fine bro...congrats on the install !! I have been meaning to ask you though... I got ~350 songs on my ipod. I tell it to go into random song mode. On the IPOD itself i can cycle through all 350 songs clicking the right button on the IPOD. I however can't track thru all 350 songs on the ipod with my head unit in the car. It may only go to 7 songs, then repeat the 7 songs again (its not always 7 songs, it may be 5 or 4, or 8 the next cycle). I have to hit the ipod ahead a few songs to get to a song i have not heard yet. Does yours do this ? Did I hear someone say in a post I read that you need a CD in the head unit for some reason ? For my issue above ? I need to try this, just have not yet. Thanks Bubbas ! Toque |
Originally Posted by GK
(Post 1568539606)
(Post 1568539606)
Use the standard track forward/reverse button to switch to next song or reverse to the previous song, and use the fast forward/fast rewind to skip ahead or reverse inside a song. Basically the same as you would operate a CD in the stereo :yesnod: Hope this helps. Toque |
When I did mine last year I added 1 extra step:D
http://img.photobucket.com/albums/v1...er/door013.jpg |
Nice write-up...thanks :thumbs:
Originally Posted by Bill Vett
(Post 1568544016)
Toque |
Once you have the ipod in the car, you wonder how you ever did without it. :cool:
Good job on documenting the installation procedure. :thumbs: |
Originally Posted by Novat_99
(Post 1568544963)
:iagree: |
