Loaded Kick Panels
A friend and forum member needed a little help loading their new kick panels with new speakers for a modern stereo system. I offered to do the work, so he shipped me the kick panels, speakers, and some sound deadener. The Dynamat they sent was in horrible shape...ripped and creased...I was NOT going to use it. I replaced it with some Damplifier that I had on hand, and completed the set of kick panels. These pics were taken before boxing them up, and they are going out tomorrow.
I'm just posting these an example so it's seen from front to back and people can see how different speakers can look in the kick panels. http://i106.photobucket.com/albums/m...tKickFront.jpg http://i106.photobucket.com/albums/m...ftKickRear.jpg |
Is there enough room for the speaker behind the kick panel? Nice work by the way!
Those look nice . . . good job!!! What size speakers are those?
BTW . . . welcome back. |
Originally Posted by Bruthish
(Post 1568611368)
BTDT. Thanx to some expert advise.
Thanx again Matt. They look great. Waaay better than mine. :yesnod: Mark http://i260.photobucket.com/albums/i...eftSpeaker.jpg http://i260.photobucket.com/albums/i...r/DSC02754.jpg |
Originally Posted by Jason Staley
(Post 1568611995)
I guessing they are going to have to do some cutting. There is barely enough room behind those panels for 4x6" speakers.
(Post 1568611995)
The magnets on my 6-1/2" Polks fit perfectly into the void in the birdcage without cutting. (Pics above). I figured that's why Db suggested them to me. |
Originally Posted by xccter
(Post 1568612415)
I figured that's why Db suggested them to me. Yes, that's correct. That's one of the reasons I suggest that brand and model. The speakers I used were purchased by the customer for their own reasons. I have yet to test fit them but they seem like they might fit also without any cutting. If cutting is needed he is prepared and aware of the process. There is not room for the 6.5" speakers behind the kick panels, to be mounted to the birdcage. Smaller speakers will fit but the basket and magnet need just a bit of extra room...which is why they are mounted in the panels themselves. |
Originally Posted by Durango_Boy
(Post 1568612986)
There is not room for the 6.5" speakers behind the kick panels, to be mounted to the birdcage. Smaller speakers will fit but the basket and magnet need just a bit of extra room...which is why they are mounted in the panels themselves. http://img.photobucket.com/albums/v1...panels-004.jpg http://img.photobucket.com/albums/v1...rsredB-004.jpg |
I assure you that the 6-1/2" round Polks did not require cutting of the birdcage in any way.
What it DID require was pin-point accuracy in positioning the speaker in the kick panel so that the magnet fit in the birdcage opening. No room for error whatsoever. |
(Post 1568614191)
Originally Posted by paul 74
(Post 1568614274)
OK, I stand corrected. Love to see the install without cutting metal. I might go for it.
The Polk DB651s I recommend do not require cutting. However, higher power speakers with larger baskets and larger magnets will require cutting. The upside is the cutting, or trimming, is very easy, can be done fast, and is undetectable with the kick panel in place and hard to spot even without the kick panel if you post-prep the area properly. |
(Post 1568614191)
DB, do you know if the 6501s would fit with out trimming the birdcage? im kinda toying with the idea of throwing those in.
Originally Posted by another-user
(Post 1568617128)
No I have not demoed those speakers. Sorry. |
well, heres the sizes on them. dont know if this would help you or not.
DB651 Top Mount 1-5/8" (4.13cm) * with adapter ring Bottom Mount 2-5/16" (5.87cm) DB6501 Top Mount 2" (5.08cm) Bottom Mount 2-5/16" (5.87cm) |
DB,
What are you currently running in your car? What about Curtis 74? And, did they require cutting? |
Originally Posted by FRSTR90
(Post 1568618092)
DB,
What are you currently running in your car? What about Curtis 74? And, did they require cutting? I am running a set of Cadence components, and Curt has CDT coaxials. Both of ours required cutting. |
Do you have any pics of what you cut? I would love to go with 6.5s up front in the kicks, but I wouldn't really want to cut on the birdcage.. Right now I got some 4" bostons tucked behind the kicks, and it just straight up sounds like sh1t. I wasn't expecting much out of these speakers, but i must say they were the biggest waste of money. So, if you wouldn't mind, could you recommend me some decent 6.5s that would not require cutting. Also, if you have pics of the what you cut, could you give me the model of speakers you have in your car (I'm assuming that your happy with them)?
(Post 1568612415)
