More Stock Dyno Numbers
I took my car to a local shop, VAspeed, to get some baseline numbers yesterday. The shop uses a dynojet. Here are the results.
http://i229.photobucket.com/albums/e...ncorrected.jpg http://i229.photobucket.com/albums/e...-Corrected.jpg The first set is the uncorrected numbers and the second is using the SAE correction. The owner of the shop explained to me that for forced induction engines that the SAE correction factor is not accurate and that in most cases the Uncorrected numbers are closer to the actual. He explained that the SAE 1349 standard is set up to correct for naturally aspirated engines only. Forced induction engines only should be corrected for air temperature and humidity. Since forced induction engines create their own air pressure in the intake manifold pretty much regardless of the barometric pressure, correction for the atmospheric pressure is not necessary. If you use the SAE correction factor it could artificially lower or raise the results. Yesterday when I dynoed the air temp was 71 deg F, humidity was 8%, and the pressure was 30.42 in-Hg. The SAE correction factor was .95 mostly due to the high pressure as the temp and humidity were pretty close to the SAE standard. I thought I would share this with you guys and see what you all thought. |
i know ranger was looking for the xls format of these numbers do you think your tuner can get those to you
Thom |
Originally Posted by Naeblis
(Post 1569047624)
Thom |
sick baseline!!!!!!!
That’s about right, 16% drive-train loss.
:thumbs:, :thumbs:
Originally Posted by GForceSS
(Post 1569051032)
OR another way to look at it...
So you're saying the correction factor doesn't really apply to your car because it's supercharged...that would mean we should be looking at the 563rwhp number and not the 534rwhp number, right???
So given the SAE certified HP number GM has of 638 this would mean your car only has a less than 12% driveline loss, is there any reason you can think of that your car would have a more efficient driveline than 'normal'??? While there is some merit to the theory that being supercharged means you're bringing along your own atmosphere and thus are less handicapped by what mother nature happens to provide you with, in reality the driveline loss should remain very constant and that means your 563rwhp number isn't as 'real' as you'd think...unless of course you have a 'factory freak' but let's NOT go there :eek: Why is it that people can't just be happy with the factory provided hp number, it's by far the most accurate number you're even gunna get. Of course once you start to modify, the factory number is no longer relevant, but getting a rwhp dyno number on a stock car is pretty dumb, particularly if all you're going to do is talk about it and not use it as a baseline tuning figure to build upon. Cheers, Paul. |
Originally Posted by MTIRC6Z
(Post 1569054887)
(Post 1569054887)
So given the SAE certified HP number GM has of 638 this would mean your car only has a less than 12% driveline loss, is there any reason you can think of that your car would have a more efficient driveline than 'normal'??? While there is some merit to the theory that being supercharged means you're bringing along your own atmosphere and thus are less handicapped by what mother nature happens to provide you with, in reality the driveline loss should remain very constant and that means your 563rwhp number isn't as 'real' as you'd think...unless of course you have a 'factory freak' but let's NOT go there :eek: Why is it that people can't just be happy with the factory provided hp number, it's by far the most accurate number you're even gunna get. Of course once you start to modify, the factory number is no longer relevant, but getting a rwhp dyno number on a stock car is pretty dumb, particularly if all you're going to do is talk about it and not use it as a baseline tuning figure to build upon. |
So since the Z06 is rated at 505 and cars are putting down 440-450, you think 12-13% is the way it is for all manual cars? I bet you think gear ratio has no affect on the dyno either. The only real way to know is to pull your engine, dyno the engine alone, read it at the rear wheels, and then calculate. As for the 9%, that’s the most efficient car on the planet, grats. :leaving:
(Post 1569062025)
Originally Posted by racerns
(Post 1569063857)
No but that does seem to be the trend for Corvettes though and you pretty much can't deny it with the numbers being put down by stock Corvettes. I am not sure what your problem with the 457 dyno number by a stock Z06, that was not that uncommon. Do I really bellieve it was really only 9.5% loss? no not really just really good weather condtions that the correction factors did not fully adjust for. Also remember, the old rule of thumb for drivetrain loss (I always used 15% myself for a manual) came from before then new SAE certification process. I am fully aware of what gear ratios can do to dyno rwhp dyno numbers as I have a new G8 that does not have a 1:1 gear to dyno in.
I thought the zr1 uses a different clutch, transmission and differential than the z06... possibly making drivetrain loss greater?
ZR1 clutch is twin-disc, probably a little lighter than the Z06, but I can't see it making much difference.
ZR1 trans is a TR6060 same as '08 and '09 Z06s, granted the ratios are a little different but 4th gear is always 1.00 and that's what's used to measure RWHP, so I can't see it making much difference. ZR1 diff has stronger cases, better bearing support and billet pieces where the Z06 is forged, but ring/pinion is the same as is the ratio at 3.42, so I can't see it making much difference. I know of a few of cases where Z06s (after being modified) were measured on an engine dyno and then later measured in the car, driveline loss was always in the 15-16% range. This is why I was sceptical about a loss of under 12% for the ZR1 in question. However if you assume a 99% correction factor then the RWHP becomes more like 557 and the driveline loss at least gets to above 12%. Interestingly if you take the fully corrected RWHP at 534 it ends up with a loss of just over 16%. Cheers, Paul. |
I happen to think there's an inherent flaw in using a percentage to calculate drivetrain loss.....if you have a 400 hp engine that makes 350 RWHP (50 HP for a 12.5% loss) through a stock driveline, and you then supercharge said engine to make 600 HP, the same 12.5% drivetrain loss would mean you're now using 75 HP to turn the EXACT same drivetrain....
Obviously, an aftermarket clutch, half shafts or some other beefed up parts will change parasitic loss a small amount, but I think it's erroneous to calculate using percentages in a very high horsepower build. Unless the drivetrain is COMPLETELY different, I would think the drivetrain is going to use roughly the same amount of horsepower to turn it no matter how much horsepower the engine in front of it makes. |
Your "inherent flaw" thought would have a little more merit in all the gears involved weren't helical, but even at that you'd still be mostly wrong. At best you could think the loss would be a fixed amount + a variable, but the amount that's fixed is small enough that just going with a variable is going to be pretty accurate. Point is, going with JUST a fixed amount (like your 50hp example) isn't even close to being right.
Cheers, Paul. |
nice
Originally Posted by JSB LS3
(Post 1569068298)
Nice numbers :cheers: I'll have to see this car in person sometime.
