Sway Bar Diameters
I did a search and cant find the info.
I have a 98 Coupe that had the Front sway, shocks and springs replaced with 04 Z06 parts but the rear sway looks stock. Does any one have a list of sway bar diameters? Even some diamters from the C6 cars to see what the difference is (if any). Thanks for the help! Jimbo:cheers: |
There's a sticky in C5 Gen - Weights, Measurements, Etc. Has a ton of info.
FOUND THIS IN SEARCH
All second hand info, mostly collected from the forums here. Swaybars: * C5 Base Suspension: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness * C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear * C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear / 4.15mm/3mm thickness * C5 Z06: 30.0 mm-front / 23.6 mm-rear / 4.5mm/3.5mm thickness * C6 Base: ?? mm-front / 22.0 mm (7/8")-rear * C6 Z51: 31 mm-front / 25.4 mm (1")-rear * C6 Z06: 31 mm-front / 28.8 mm-rear * C5 Hotchkis: 31.75 mm-front / 25.4 mm-rear / 4mm/4mm thickness * C5/C6 Addco: 32 mm-front / 25.4 mm-rear * C5/C6 Addco: 35 mm-front / 25.4 mm-rear * C5 Pfadt (Adjustables): 32 mm-front / 26 mm-rear http://www.pfadtracing.com/ * C5 Pfadt (Adjustables): 35 mm-front / 28.5 mm-rear (Pfatty) * C5 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6.35/6.35 thickness * C6 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6mm/?? thick Springs: * C5 Z06: 526# Front, 714# Rear * C6 Z06: 531# Front, 782# Rear * C6 Z51: 526# Front, 645# Rear * T1 (C6): 582# Front, 850# Rear * C6 Base: 420# Front, 657# Rear (VBP: 400-420 F / 600-620 R) * T1 (C5): 582# Front, 793# Rear * Pfadt Coil-overs: 425# Front, 575# Rear (Remember: Wheel rates!) * Hyperco HPS (Street): 565# Front (12405HPS), #765 Rear (12406HPS) * Hyperco HPT (Track/Solo): 625# Front (12407HPT), #850 Rear (12408HPT) * VBP Sport 990# Front, 650# Rear * VBP Extreme 1050# Front, 855# Rear |
Thats what I was looking for!!! Thanks
Jimbo |
