'85 LT1 TH400 conversion
Posted over in C4 Tech as well, but thought the actual racers here might appreciate this.
For those who know this car (Blackbird), it's our shop "test bed" for different things. I decided to make a dual purpose streeter out of it. Swapping the heavy-assed Center Line wheels for some Greg Weld Motorsport big 'n littles, the decision was to make it more drag race oriented. Pic as it looks with its new wheels: http://i12.photobucket.com/albums/a2...birdWelds1.jpg For power, I decided to try something a little different: put a later style LT1 (the one from my '96) into my '85 to replace its very tired L98. The '85 already had a carb conversion done (with adjustable plate nitrous, of course), so we swapped to a carbed intake with MSD billet distributor: http://i12.photobucket.com/albums/a2...s/IMG_5546.jpg Pulled the 4+3 manual trans in favor of an automatic - decided to use a TH400 for reliability over a 700R4 (and a 3600 stall nitrous converter to help launch capability). A conversion bracket was fabricated to attach to the existing C-beam: http://i12.photobucket.com/albums/a2...s/IMG_5477.jpg Closeup of bracket: http://i12.photobucket.com/albums/a2...s/IMG_5476.jpg Did a little tunnel surgery to fit the B&M shifter, to help it fit within the confines of the stock console. Here's how we did it: http://i12.photobucket.com/albums/a2...s/IMG_5487.jpg The result with the console back in place: http://i12.photobucket.com/albums/a2...s/IMG_5543.jpg A closeup, also showing the dual function switches for the cooling fans and electric water pump (down for "auto"-keyed power, up for "manual" battery hot for between rounds cooling): http://i12.photobucket.com/albums/a2...s/IMG_5545.jpg All that's left is to fabricate the gauge cluster for the Auto Meter Pro Comp UltraLites. (and maybe drive the damned thing one of these days!) :D |
Real nice work, Robert...should be a good runner...I dropped my converter off at FTI today for a refresh and my 400 at Ken's in Orlando to get freshened up as well...
Nice install .Did you have to cut the tunnel to clear the bell housing?
Do you have a pic of the top of the c-beam? |
Interesting choise of carbs. Nice conversion.
I was going to say something about that carb.If you can get one of those to work on a chevy more power to you.:thumbs:
Change to a holley and watch the motor come alive. |
Cool car,
For some reason I thought it was leading up to a Car is For Sale thread, lol. |
Originally Posted by REDC4CORVETTE
(Post 1569429344)
(Post 1569429344)
Change to a holley and watch the motor come alive. As far as cutting the tunnel... this was a 4+3 manual trans car, so the tunnel on the LH side protruded in for the shift linkage (really stupid design, IMO), which may have interfered a bit. That tunnel section was removed primarily for the shifter mounting, but the bellhousing cleared with no trouble. An automatic equipped model would likely need no tunnel mods, save for lowering an aftermarket shifter. No pics of the top of the C-beam, sorry (plenty of clearance, tho) |
So I'm bringing this up from the dead, if you have any information about how you got VSS to work I would like to know aswell since I have an 86 4+3 car that I'm going 400 on but will be turbo LS.. Anything to make this a more understood process would be great since I will be starting the project in a couple months. Thanks in advance
Originally Posted by Slow86vette
(Post 1588715673)
Once you go to a 400 you will be changing the car alot and it will become a nice ticket machine,I was running over 700 hp and after awhile I pulled it off the street .I also installed a 4 link.I also had to install a universal shifter and a 5500 tq converter.:thumbs: |
(Post 1588715702)
I dumped it on mine when I went to a th 400 .I bought an electric spedo that I got from Summit racing ,it works off magnets on the drive shaft.
(Post 1588715713)
Yes my plans are 600 whp turned down and 800 on kill, could you link me to one of those electric speedos? I'll need an aftermarket speedo or cluster for this won't i?
I have to look up the spedo at Summit but this may give you a clue. http://www.summitracing.com/search?S...c%20spedometer It's just a game of money!! |
(Post 1588720373)
http://vettaid.com/ReplacementGauges...ePackages.aspx
What's up Fuzzy and Red... you guys going to the track on the 30th of January?
