Jet Hot Coating
We added jet hot coating to my headers and mid section this winter because the ls7 was generating a lot of heat on the track. We felt that the oil lines were too close to the headers to be comfortable with continuing with heat wrap and the inside tunnel was extremely hot so we sent everything out for extreme coating.
Jet hot located in PA returned my headers on schedule within the 10 days they stated which was nice. Last weekend at NJMP I did some temp checks against another header on a 346 H/C car with headers. After we got in the garages I checked my temps and then the uncoated headers temp. I found my temps to be a bit over 200 degrees cooler (180 vs 380). I also noticed that my temps would drop faster than the uncoated headers while we sat there. This was good news but threw off my initial testing because from the end of the session to the garage I was dropping faster so I don't know what my high temp was compared to the high temp of the uncoated. We will be at WGI next month and I want to do more testing, but for now I am very happy. The coating is also very shiny so I wonder how long that will hold up. |
The headers on my 02 Camaro are Jet Hot coated. They are still bright and shiney after six years.
JetHot is great stuff; I wouldn't run uncoated headers on any car of mine after seeing how much of a difference the coating makes...
Here are my Kooks after about 15,000 miles of use: http://www.powerlabs.org/images/c6/headers.JPG |
How much does it cost to have a set of headers done?
That's a dramatic difference. I've always believed in coating headers but most guys don't because of the extra cost. Many think coating is simply for appearance...they don't realize the functional, real world benefits. This is from Jet-Hot:
"The coating promotes denser, more potent fuel/air charges by insulating the engine bay from exhaust heat. Also, it accelerates the pulsed-vacuum effect on “tuned” headers, resulting in more effective scavenging of cylinders. The increased velocity of exhaust gases produced by higher exit inertia not only clears each cylinder more quickly; it also draws in the next fuel/air charge more efficiently." Thanks for sharing your findings...good post! :thumbs: |
I used them for the exhaust on my airplane. I didn't use the silver coating because it can't stand the prolonged high temperature that an aircraft engine sees, but their Jet-Hot 2000 product has held up fine. The Jet Hot 2000 is flat black and rough (looks like hell, actually), but has not shown any wear after 200 hours of 1500+ EGT. Good company, good products.
I did the Jet-Hot coating thing on my LS7 pipes too. I had the stock manifolds, the Cat Pipes, and the long H-Pipe coated with Extreme. Cost was right around $400 for all. (Plus new gaskets).
I also thought the stock exhaust ran too close to oil lines and engine components. So I bought a package of 2" wide heat wrap and did the downpipes. I was very pleased with myself until I started the engine. That heat wrap really stinks! After two months of occasional driving, the smell has gone away. While I had the car up on jacks, I decided to do some simple insulating in the tunnel area. I bought some really nice peel-n-stick insulation that has a shiny, thick aluminum face, about 1/8" thick insulation, and then the adhesive. It's the same stuff that's on the Thermal-Abs. I removed my Thermal-Abs tunnel plate and put a layer of this insulation above the tunnel plate (but not along the edges where the screws go through). Since I had the tunnel plate off, I covered some places near the shifter that the factory left exposed. I then added insulation along the sides of the tunnel just below the plate. I love driving this car, but last summer it was way too hot when the windows were down and the A/C was off. After all this, I'm expecting a much more civilized ride this summer. John |
Originally Posted by Wayne O
(Post 1569486389)
Originally Posted by JohnRR
(Post 1569489086)
John |
I bought the peel-n-stick material off of eBay. The seller said he bought it as surplus from the Shelby factory. If I can find his name and address, I'll shoot you a message.
John |
A lot of good info on this post:thumbs:
I had my LG's coated as well, although I went to a local shop and it was about half the cost of Jet Hot and they did an awesome job. :thumbs:
WW, could you detect any change in the sound of your exhaust with the jet coating? Quieter?
Originally Posted by PowerLabs
(Post 1569483918)
Originally Posted by tsts
(Post 1569631479)
Did your exhaust sounds lessen? Any quieter? Different?
The coating is thinner than a sheet of paper; it has no effect on exhaust noise. The headers make the car louder and meaner at high RPMs but don't make too much of a difference at low RPM. |
For people that are following :
We will be testing 2 ECS built 427s at WGI in 2 weeks. Mine has the coating and the other doesn't. Unfortunately we have different headers ARH vs. LG but such is life. I will try to get measurements at different spots since last time we only did one specific area. Btw my setup is coated all the way to the exhaust. |
I'm a believer!!!!:)
under hood temps on my car are 130 cooler than before I had mine coated. as soon as I get my new Lg Super Pros they will be getting coated!! and I'm also doing the X pipe.:lol: |
Originally Posted by Wicked Weasel @ ECS
(Post 1569634274)
We will be testing 2 ECS built 427s at WGI in 2 weeks. Mine has the coating and the other doesn't. Unfortunately we have different headers ARH vs. LG but such is life. I will try to get measurements at different spots since last time we only did one specific area. Btw my setup is coated all the way to the exhaust. Great mod and should be done when you get the headers done saves money in the long run. Ernie |
Originally Posted by oliveiraej
(Post 1569645961)
Hey Bob, great post, I will ask the guys what they would charge to get the same thing done on my Z.
(Post 1569649498)
Yeah if you think you want it then get them coated prior to putting them on. Not that it is alot of extra money to take the headers off and reinstall, but your car will be down for 10 days or so while they get coated.
