c5 build sheet and window sticker
I have read on the internet that you can find the production build sheet hidden in the front reinforcement bar. I was wondering if anyone in the forum has found this to be true. If this is true can you please let me know where is the location. I have tried to look but have not found it.
I also need to know if anyone out there has any suggestion on obtaining the build sheet if it's not in the front reinforcement bar. I'm also trying to get the original window sticker. I called the dealer the car came from and they were no help. I'm the second owner of my 2002 c5. Thanks Dennis |
You can obtain both of those from the NCM.
www.corvettemuseum.com |
The build sheet can be found in the square tubular cross member at the front of the cars frame (the far left in this picture). NOT easily accessed.
http://www.idavette.net/c5/frame1.gif OR, you can order new Build Sheets and Window Stickers => HERE |
Glenn
thanks for the info. I ended up ordering all the documents from NCM. Thanks Dennis |
I accidentally found mine while cutting into front bar,... it was in bad shape ... taped it up and framed :thumbs:
