Best way to get wax off trim?
I just bought a '08 C6, and the previous owner (or the dealer) got some wax on the black rubber trim and didn't get it off.
So now it has those white stains on it. What is the best way to get those stains off? :cheers: |
Also curious, I did a sloppy wax job on my DD.
Stoner's Trim Cleaner
There are a number of ways to remove wax residue, but for me the easiest way is to wipe with Meguiars #39 Heavy Duty Vinyl Cleaner. It removes the residue effortlessly and leaves the trim looking better than before you waxed.
Originally Posted by johnodrake
(Post 1569847208)
Plain old alcohol (or vodka) will do the trick.:thumbs:
CHEAP vODKA OK. And dont use wax use a sealer it's better
When wax dries and sticks to trim pieces, an easy solution is to reapply the same wax to the problem area and wipe it clean before it dries again. Wax does a good job cutting itself.:thumbs:
Peanut butter. No lie. It works great.
-Mike |
Originally Posted by ro2516
(Post 1569847295)
Originally Posted by chupr0kabra
(Post 1569847338)
-Mike |
Back to Black removes it easily.
:iagree:
Originally Posted by yello9
(Post 1569847589)
A little No. 2 diesel fuel would be the cheapest approach. Similar petroleum solvents are the thinners in most liquid waxes.
Just be careful with alcohol, as it can dry out the plastic over time. If you use alcohol to remove wax, remember to give it a good coat of trim/plastic treatment. Personally, I use Meguiar's Natural Shine.
-Mike |
3M Adhesive Remover or Stoners Trim Cleaner. :thumbs:
zaino z16. and it blackens the trim at the same time.
(Post 1569847589)
peanut butter does indeed work, then follow up with Poorboys Trim Restorer to make the trim pieces look new for months.
www.autogeek.net |
I ended up getting some Mother's Back to Black, and it worked great.
Thanks! |
