C5 Bose upgrade wiring notes
C5 Bose CD or cassette upgrade wiring notes
Bose CD/Cassette Stereo System Info: The C5 Bose stereo system is based on a modified Delco head unit. The "Delco/Bose" head unit, CD or cassette, has four connectors called C1, C2, C3 and C4 on the rear panel. C1/C2, which is a single siamese connector, is used for many Delco head units, not just Bose. The wiring is different though in various cars. C1/C2 carry power, ground, BCM data and the front and rear speaker wires. There is no switched power on the C1/C2 connector, the BCM controls powering up the head unit. Connectors C3 and C4, provide interfaces to the head unit front/rear pre-amp outputs and front/rear power amp inputs. The pre-amp's audio outputs on connector C4 go to the BOSE Signal Processor, BSP, mounted above the throttle. The BSP "conditions" the front/rear audio signals and then sends them right back to the head unit internal 4 channel power amp. The basic crossover frequency of the BSP is 1 kHz. The BSP probably also does ambience and spatial enhancement to the audio signals. The BSP in the Coupe is different than in the Vert and FRC. The head unit internal power amp is about 15-18 watt rms/ch and drives the 4 front and rear Bose midrange/highs speakers called Twiddlers. The rear Twiddlers are 5.25" in the Vert and FRC, 6.5" in the Coupe and the fronts are 3.5" in all vehicles. The Bose system has no true tweeters. The BCP also sums the audio information from all 4 pre-amp input signals and sends it unfiltered to the two sub-woofer amplifiers in the doors. The sub amps have an internal low frequency crossover. These two class D sub amps feed two reverse cone 8" "sub-woofers" in the doors. They are mounted next to the front 3.5" Twiddlers behind the door speaker grills. Some of the problems with the stock Bose system are: 1. Speaker placement. The mid/high frequency speakers are horribly placed. The front Twiddlers radiate at your feet and the rears radiate at each other. High frequency drivers are very directional like a flashlight. They need to point directly at the occupants. 2. Lack of highs. There are no tweeters in the C5 system. The system should have had pillar mount tweeters. The front Twiddlers are really upper mid-range drivers. 3. Gain imbalance. The subs level and the mid/highs level is not ideal. It seems that Bose/Delco is trying to use the bass control as a subs level control. It does not work correctly. It has a very low frequency turnover frequency compared to other Delco head units. The system should have at least three level controls, subs, mids and highs. 4. Low mids/high power amp gain. The Twiddler power amps in the Bose/Delco head unit have their gain set very low. I don't know what Bose was thinking. You cannot drive the front and rear Bose Twiddlers to full level on many CD's and certain radio stations, yet you can drive the Bose subs to full level any time. I modified my head unit to fix this problem in my hybrid system. 5. Lack of audio power. The Bose/Delco system has six power amplifier channels. Four channels are in the head unit and two small class D amps are in the doors. The 4 channel internal AB power amp in the HU is about 14 -18 wrms/ch into a 4 ohm speaker. This amp drives the four Bose Twiddlers. The door class D sub amps are about 35 to 45 wrms each into a 2 ohm speaker. Each sub amp drives a 2 ohm Bose reverse cone sub woofer. Since the Bose system has no DC to DC converter like an aftermarket power amp would, the amps are running directly off the alternator's 14 volts. The Bose system should have had an external six channel power amp module with high power. They could have taken the money wasted on the external Bose Signal Processor and sub amps and put it into an external amp. 6. No external auxilliary audio input connector. It this day and age, the head unit should have had a set of RCA connectors under the dash for a MP3 player or what ever one wanted. The deck could do this now if it had different software in it. Audio interface info: All low level audio interfaces in the Bose system are psuedo-differential. These include pre-amp, power amp, signal processor, subwoofer signals and CD changer. All high level speaker outputs, head unit and sub-amp, are fully differential. A psuedo-differential wiring scheme is one that shares one return signal wire for many signal source wires. A true differential wiring scheme uses two wires per signal. Using psuedo-differential or true differential wiring for low level signals improves noise rejection. Pseudo-differential wiring costs less than differential wiring and does not reject noise as well. Using differential wiring for high level signals improves voltage swing by 2x and thus power level. 2x the voltage swing is 4x the power. A typical single ended power amp powered by +14 volts, will put out 4 watts. A typical differential or balanced power amp running off +14 volts, will put out 16 watts. NEVER ground any psuedo-differential or differential signals to chassis. You may damage the internal differential circuitry. There is a dedicated floating Common return signal for each low level interface. DO NOT use the Common signals to interface to any external equipment. The Common signals in the C5 audio system are non-standard and should only interface to Delphi or Bose equipment. The 4 Common signals on the head unit and BSP have a DC offset on them. If you ground any of them you may do damage to internal circuitry. Only use a high impedance interface to tap a pre-amp outputs to feed external amps. For a power amp input signal return, use the shield wires or chassis. Tapping a differential signal with a single wire is OK, but you will not get the same noise rejection on long cable runs. Bench Testing: The C5 head units used in the coupe, FRC or vert are under control of the Body Control Module, BCM. The head unit cannot be tested outside the car without connecting a spare BCM to the DLC data buss interface of the head unit. The BCM controls power ON/OFF, illumination, SVC and radio pre-sets of the head unit. Simple Modifications: Replace the rear Bose Twiddlers with 2 or 3 way speakers. This will improve the highs. Unfortunately the speakers are poorly placed and do not radiate at the occupants heads. Buy speakers with swivel tweeters or that have the high frequency drivers angled at 45 degrees. Connect real tweeters in parallel with the rear Bose Twiddlers. Point the tweeters at the occupants heads. They can be mounted on the car pillars. Add a subwoofer to the system. Connect the sub amp to the HU rear channel pre-amp outputs. The Bose CD/Cassette head unit can be utilized without the Bose signal conditioner, Bose sub-woofer amps and speakers by using the head unit four pre-amp outputs to drive external aftermarket power amplifiers and speakers. Use the Shield wires or chassis for signal return. DO NOT USE signals Common on C4(13),LT BLU or Common C4(7),YEL. These signals are only to interface with the Bose signal conditioner. The head unit Radio "ON" output can be used to switch on external power amps. Be safe and use an in-line .5 amp fuse to protect head unit. Wiring info: The following are the Bose head unit 4 channel pre-amp outputs Signal CD/Radio Color code LF out C4(9) TAN/BLK RF out C4(10) LT GRN/BLK LR out C4(11) BRN RR out C4(12) DK BLU Common C4(13) LT BLU, DO NOT USE FOR EXTERNAL POWER AMP Shield C4(14) Bare wire Ground C4(15) BLK The following are the Bose head unit 4 channel power amp inputs Signal CD/Radio Color code Common C4(7) YEL, DO NOT USE FOR EXTERNAL POWER AMP Shield C4(8) Bare wire LF in C3(1) DK GRN RF in C3(2) LT GRN LR in C3(3) BRN/WHT RR in C3(4) BLK The following are the head unit power and control signals Signal CD/Radio connection Radio "ON" C1(8) DK GRN, Switched 12v used to turn on power ant and Bose modules Power C1(10) ORG ground C1(5) BLK/WHT The following are inputs to the Bose signal conditioner Signal Bose signal processor connection LF in B5 RF in B7 LR in B6 RR in B8 Common A4 The following are Bose "conditioned" outputs fed back to the head unit 4 channel power amp Signal Bose signal processor connection LF out B2 RF out B12 LR out A2 RR out B10 Common B3 The following are Bose "conditioned" outputs fed to the front door sub-woofer amps Signal Bose signal processor connection RH out A9 RH return A11 Drain B9 LH out A3 LH return B11 Drain B4 Bose signal processor power connections Power A12 SW +12 in A8, turn on processor Ground B1 Bose Bypass info To bypass the Bose Signal Processor, make the following jumper using the C3 and C4 connectors in the wiring harness. Connect the following color wires together. Please check the wires per the info above. There is two BLK wires, one is a signal wire and the other is connected to chassis ground, C3(4) is the one you want. Solder the connections and tape them up. Do not cut unused wires, you may want to add a power amp later and you will need these for signal returns. C4(9) TAN/BLK connect to C3(1) DK GRN C4(10) LT GRN/BLK connect to C3(2) LT GRN C4(11) BRN connect to C3(3) BRN/WHT C4(12) DK BLU connect to C3(4) BLK C4(13) LT BLU connect to C4(7) YEL Tweeter additions to Bose system When you add a "4" ohm tweeter and it's crossover in parallel with the front 3.5" Bose Twiddlers, the amplifier will see a more complicated load. The impedance that the amplifier will see will be very low where the two speakers overlap in frequency response. The front 3.5" Bose Twiddler will have a frequency response similar to any add on tweeter. In reality it may be best to put the add on tweeter in parallel with the rear 5.25"/6.5" Bose Twiddler wires. The rear Twiddler is a mid range speaker. Putting a tweeter and crosover in parallel with it will mean very little overlap in the frequency response of the two speakers. The amplifier will not have to supply as much current at a specific frequency to both speakers at once, so it will run cooler and produce less distortion. The rear Bose Twiddler wires are available on the back of the HU. RR+ C2(18) DK BLU RR- C2(17) LT BLU LR+ C2(20) BRN LR- C2(19) YEL Delphi/Bose head unit internal improvements: These mods are not to be done by someone without soldering experience with surface mount components. The Bose CD deck with the FRC bypass will not drive it's internal 4 ch power amp to clipping on some radio stations or selected CD's. It is not a real problem, but some old CD's were recorded at very low levels. These old CD's usually sound like crap because old tapes were used as the source material and there is a lot of hiss on them. If you like your music loud, then you will need to modify the head unit power amp for more gain. Most head units can overdrive their power amps to clipping for even low level inputs. I have a fix to increase the gain of the internal power amp. You need to replace four chip resistors. The mod requires changing out four 1206 size surface mount chip resistors. The head unit power amp has 4 op-amp based attenuators feeding it. Lower the attenuation and the power amp gain will go up. The Bose head unit has a modified bass control to work with the subwoofer. When put in a system without a sub-woofer, the control does very little. A normal bass control has a turnover frequency of about 1khz. The Bose HU control is under 200 hz. The stock speakers in the FRC cannot reproduce the sub frequencies. I modified my bass control to work like standard Delco deck. The change requires changing out some surface resistors and capacitors. This mod improves the bass enormously. I have also gone through the circuitry and improved the low and high frequency response of all the audio circuitry. These changes required increasing the coupling capacitor values by 2x to 10x and eliminating some shunt capacitors from the C3/C4 interface. Head unit gain and bass control modifications: The resistors and capacitors I changed are on both sides of the head unit motherboard. I will only describe the gain and bass control mods for now. The other mods I did are too much for most people to attempt. The other mods only enhance the bass and highs more. This is something you will probably not need to do. DO NOT force anything. Be patient. To get at one side of the motherboard, you need to remove the radio circuit card, this is easy. To get at the other side requires removing the CD assembly. It is fastened with four screws. This takes more time because you must remove the front panel to get two of the screws. Remove the big knobs only and the nut and washer on the volume control. Be very careful removing the front panel. It is plastic and is clipped onto the metal chassis in many places. Work each "clip" free individually. Be careful removing the CD assy. There is a long ribbon cable attached to it. You must release the tiny compression clamp on the ribbon connector on the CD assy motherboard, to pull out the ribbon cable free. The four resistors to changed the power amp gain are near the two SO-14 and one SO-8 IC packages used for the pre-amp output and power amp input buffers. The two 14 pin IC's are quad op-amps and the 8 pin IC is a dual op-amp. The resistors are clustered around one of the 14 pin SO-14 package IC's next to the C2/C3 connectors, under one of the RTV blobs. You need to remove the RTV blob on top of the IC. Leave the rest alone. The resistors are labled 5491. This means 5.49K ohm 1%. You need to replace them with four 12K to 27K ohm, 1206 size chip resistors. The larger the resistance value, the higher the power amp gain. To mod the bass control circuit, locate the small 32 pin PLCC packaged tone control IC near the large Microprocessor IC. The bass control's 2 resistors and 4 caps are on the other side of the motherboard under the tone control IC. Look for two 1206 chip resistors labled 302 that connect to ground. This means 3K ohm 5%. There are four caps connected to these two resistors. It is a "T" network. For the R+L channels, two caps attach to the IC and the resistor hangs between the two caps to ground. The two resistors need to be replaced with 4.3K to 5.1K 1206 size chip resistors and the caps replaced with .1uf 1206 size chip caps. Be very careful removing the old parts. Heat up both end terminations of a the chip component at once with a soldering iron. Use some extra solder to help transfer heat and work the tip back and forth between the ends. Make a small solder ball if neccessary. Gently push the part off the pads with the soldering iron tip when both terminations are floating free. Clean up the board pads with solder wick. Clean the board with a Q-tip and some alchohol or acetone. Use tweezers to hold the new parts to solder them. |
Re: C5 Bose upgrade wiring notes (99HT)
99HT,
Excellent stuff, thanks! I bought a spare radio and am now inside looking around. I want to get some kind of Aux input going. Do you have any suggestions? Thanks for any help. Gary '99 Pewter/oak coupe MN6/Z51/etc. |
Re: C5 Bose upgrade wiring notes (C5GARY)
Unfortunately, you cannot use the AUX/CD changer input unless you can sent the correct data messages up the E&C bus to fool the HU into believing a CD changer is connected.
I am working on a microprocessor based module to do this, but it is going to take me a while to finish. I finally got a CD changer today in the mail to use for testing. Reverse engineering the message structure on the E&C bus is a PITA, since it is not any standard protocol or interface. The sleazy way to add an external input is to cut the board traces coming from the FM tuner or the CD player and bring four shielded cables out of the HU. You can then use a SPDT switch to send in an AUX source. |
YES, I read your other posts about this. I'm inside, gonna cut whatever I
need to!! ;) Can you give me any other pointers before I mess up? I was thinking a relay inside somewhere just before amps.. would like to find the original 2 channels before is gets split to 4 channels. Want to automatically kill whatever is playing now (radio or tape) when the phone rings... :) Cap coupled should work I guess. I guess I could just do it externally at the Bose processor :confused: WOULD like the solution to be hi-fi, want to direct connect in a CD too. Thanks for any ideas! Gary |
Unfortunately there is a single IC that handles ALL the duties of input switching, volume and tone control. This limits the mods you can do.
Go look up the IC, TDA7342. This IC is "almost" exactly like the custom version used in the Bose HU. Only a few audio output pins are different. It does everything mentioned above and is controlled by the HU microprocessor. You will not be able to do anything with this IC except alter it's audio inputs. You will not be able to control it, it is totally under software control. The two Twiddler power amp IC's are "almost" exactly like the TDA7297. http://us.st.com/stonline/books/ The inside of the Delco/Bose HU looks unlike most car HU's you may have been inside. It looks more like a piece of digital equipment, than audio. Be careful, it is easy to damage. I design products 10x more complicated than it, so for me it was no big deal to figure it out. |
So I have a question for you, HT - I'm the most resistant guy to carve into the wiring of the vette. WHat is your opinion on the AUdiolink products/ Both the PD4 and the Wiring Harness?
Re: C5 Bose upgrade wiring notes (lkasakoff)
The C5 Bose system is very different than the C4 one. I doubt that the PD-4 would do anything "extra" for you.
You need to specify what you want to do to your system. Do you want to keep the stock HU, speakers????? |
Thanks a lot 99HT, I have all your old posts printed and stapled for reference. Your research was invaluable.
Again, my most sincere thanks! Sam |
Front Swivel Tweeters?
You recommended in another post adding some front swivel tweeters to enhance the Bose stock system (2004 Vert here). Can you be more specific please? Would these be stuck/mounted on the outside of the speaker grille on the doors or? In any case, any particular model/size come to mind please? Thanks!
The easiest and cheapest way to get modest gains in the high end is to swap out the 3.5" paper speakers in the doors with aftermarket 2-way speakers. Any 3.5" 4ohm set will work, but many have been happy with Polk db351 or Boston Acoustic S35.
If you want to do more than that, read through the C5 sticky or contact C5 BearsFan (Dennis of doubledmods) :thumbs: |
Ok, I have read this a couple of times and I am still confused. If I buy this Kicker add-on powered subwoofer, I can connect the remote turn on wire to the power wire for the power antenna, and I can run a power line to the battery. I can connect the subwoofers ground wire to one of the seat mounting bolts.
So where do I connect the four audio input leads to (see page 4 of the .pdf - white, white/black, grey and grey/black wires)? Thanks http://www.kicker.com/app/manuals/po...eaway_RevM.pdf |
