Does your Master Cylinder cap leak?
I find that I have to wipe up brake fluid off of the area around the master cylinder resevoir after every session. I do not over fill my m/c and I put on a new cap, but it still sprays some fluid out of the fill cap.
Are there any tricks to tighten down the cap? I have heard of people rubber banding a rag around the cap, but to me that is a fire risk. Thoughts or solutions? cj |
Only fill the MC 1/2 way beteen the center seam and the FULL line.
Do not fill to the FULL line. Hot brake fluid expands also zip tie a small rag around the MC cap to absorb any spilled brake fluid |
The MC cap is vented, so you need to make sure the fluid level is down towards mid-level.
Have a good one, Mike |
yep, I do that and it still spays. I will try the ziptie and rag approach.
cj |
buy a new cap, it shouldn't leak if you aren't overfilling
Originally Posted by davidfarmer
(Post 1570165952)
Thanks, cj |
Are you sure it's not spraying out of the back of the M/C? That'd be bad seals in the M/C for my year.
I think this falls into they all (or most) do. Mine does. I just wipe it.
My p/s cap does the same. |
I took a Mobil 1 quart bottle and cut the front off. Cut a piece the shape of the m/c cap out of the platic from the bottle. It must just fit inside the cap. Place it between the cap and gasket. It works like a shim. It isn't overly tight but provides an little more force on the cap.
Try it, it just might work for you. Bob |
I installed a second gasket on the cap made from gasket sheet for a tight fit.
I recommend proper brake fluid level. |
Thanks for the suggestions. I will try and shim the cap.
Chris |
Originally Posted by Kanmer
(Post 1570167383)
Try it, it just might work for you. Bob I cut out an oil jug into a gasket, put it in, and the cap feels tighter already. I'll know if it works after my next drive. Fingers crossed. |
... aaaaaaaaand, it worked! :thumbs:
