SC with LG G6X3 CAM
I have an LG G6X3 cam and looking at adding a ProCharger. Should I be OK with this cam?
Also currently I have no bottom end changes, what limits should I be considering in boost? |
Originally Posted by Dan Wendling
(Post 1570255128)
I am a big fan of LG Motorsports and that cam is my personal favorite. It is not the right cam for an FI application. If you call them up, they will tell you themselves. They do make a blower cam that you can ask them about.
If they told me I could have used that cam with my blower I would have. It's an NA cam. Good luck. |
If Its in the car already, and you want to put a blower on, go ahead use it :thumbs:
If you have no cam in the car, opt for something more blower friendly :cheers: It isnt like the car will not run with a blower and this cam :D Its just not what I would sell a customer if they called and said I want to put a blower on my car, what cam should I get? Louis |
g6x3 with blower
Originally Posted by Louis @ LG Motorsports
(Post 1570297794)
They just did a stock shortblock LS3 with ported LS3 heads and that cam with an F-1A. It did over 800rwhp and 11-12psi of boost if memory serves. It was fairly recent and should be posted in the first few pages of this section.
Any aftermarket cam should make more power with a blower regardless if it's blower specific but if you want to optimize power then go with the blower specific cam.
My advice would be to limit the power right around 500-550whp and upgrade the springs, lifters and pushrods. Going to cost you a little up front but will definitely save you in the long run. |
He has the G6X3. He already has to have better springs and pushrods to run that cam.
Originally Posted by jon6.0
(Post 1586075699)
He better. I think that cam is damn close to .650 lift. With that kind of lift I would be changing springs every 15-20k as a wear item.
Originally Posted by Kadorja
(Post 1586075969)
You would be surprised...
I have all necessary hardware to support the big cam, thanks for looking out though. |
(Post 1586075066)
Semper Fi :flag: |
Originally Posted by 3rd Gen Devil
(Post 1586076448)
Prior Planning Prevents Piss Poor Performance...
Which springs?
(Post 1586078586)
Which springs?
(Post 1586078983)
Comp Cams 918 springs
Originally Posted by old motorhead
(Post 1586079160)
Those babies cost me a motor a few years ago. Later versions of the 918 spring are supposed to be better. I'll never trust another single spring because of that experience though....don't care how "good" they supposedly are.
I've got a brand new set sitting on my shelf in the garage that I won in a raffle. I was like "wtf am I going to do with these things, I won't even be able to give them away", lol.
First, the G6x3 requires the Comp 921s.
Second, we have made 820rw with the G6x3, F1A, 93, and meth on a stock bottom end LS3. Yes, stock bottom end. |
(Post 1586074687)
Have you seen supercharged ls3's run this cam and can you elaborate more on what this combo would be like? I have the same cam and am considering putting on a supercharger while I"m gone on deployment.
http://forums.corvetteforum.com/c6-f...-with-f1a.html It's all about the total combination on the car so you have to make sure everything is setup right and the tune is nailed down. |
