Turn signals.
My turn signals are flashing faster than normal but I can't find any bulbs that are out.I did replace a front bulb about a month ago when they were flashing very fast and i did find a bad bulb at that time.Do these cars have a flasher module that might be bad?
The emergency flasher in the center of the dash goes bad often here causing the symptom you're experiencing. :ack: Here's a how-to in case you need to replace your's.
http://www.kd5fx.com/HSwitch/HSwitch.htm |
that sporty son of yours must have messed this up the other night
Originally Posted by Patches
(Post 1570279956)
When you replaced the bulb, was it of the same wattage? I have seen that happen on BMW's many times when a lower wattage bulb was accidenally used.
