Tech II (need to correct mileage for an HUD install)
Is there anyone in the DC-Bailtimore area with the GM Tech II that can can correct the mileage on a cluster. I'm getting ready to do a HUD install on a 98. I need to change to a hud cluster and change the mileage to match existing.
And not to Hijack, but I'd like to do the same in Houston. I have the old and new cluster.
Originally Posted by vette.mix
(Post 1570304381)
OP check your other thread on this subject. Calgary posted a very interesting fact that if you swap the small circuit board in the back of the IPC, your mileage info will go with it into the new IPC.
I too was under the assumption that a Tech II could change the mileage.... |
I spoke with a dealership and was told that it can be done with a Tech II, my son went on the HP tuner section, that used to be able to do it but had some legal problems and had to take it out of there software- they said you needed a Tech II. I will end up going to the dealership to have it done but would rather have a fourm member do it.
Originally Posted by tstar
(Post 1570306010)
Send a PM to "PACETHIS" aka Josh he used to sell the HUD upgrade kits.
(Post 1570319824)
I'm don't think this can be done since has the HUD connectors that you need are on the newer boards, this is what PaceThis has informed me and he is very knowledgeable on HUD installs. He can do the mileage but is in S.C.
http://i142.photobucket.com/albums/r...9/IPC/back.jpg I think it's worth a shot as it's free and also you can verify for the rest of us if indeed this does work seeings how we're getting conflicting info all of a sudden... :thumbs: Tim |
Originally Posted by ajg1915
(Post 1570321962)
Tim |
(Post 1570324854)
Holy heck aig... you changed your avatar, don't tell me you finally got your beast rolling????????????????
Tim Once they come in the car will be coming home and getting a new drive train and interior. I'm putting in a 416 (LS3 / L92) combo and converting to an automatic using RPM's A4 / C6 Z06 differential along with some other suspension upgrades. Then it will be on onto the interior. I'll post up some photos when I get it home. :) |
(Post 1570324852)
No I'm not talking about the Mother Board but the smaller green PC board shown here in the lower left corner;
http://i142.photobucket.com/albums/r...9/IPC/back.jpg I think it's worth a shot as it's free and also you can verify for the rest of us if indeed this does work seeings how we're getting conflicting info all of a sudden... :thumbs: Tim Thanks for all the advise |
I have the equipment to adjust mileage. If needed please PM me.
conflicting info, will wait for results, I have some clusters to get rid of
Originally Posted by Steve Doten
(Post 1570331705)
The mileage is on the surface mounted chip (I think it's either an HC11 or HC12 chip) that's at the middle/right of the circuit board posted above. Reprogramming that is all that's needed to change the mileage (although it must be removed from the board first which is not easy without the right tools) A Tech II can not do that as far as I know. |
(Post 1570326055)
Almost, just waiting on a few more parts from GM to come in :toetap:
Once they come in the car will be coming home and getting a new drive train and interior. I'm putting in a 416 (LS3 / L92) combo and converting to an automatic using RPM's A4 / C6 Z06 differential along with some other suspension upgrades. Then it will be on onto the interior. I'll post up some photos when I get it home. :) Tim |
Originally Posted by schpenxel
(Post 1570331813)
What conflicting information are you referring to? I'm fairly certain I can clarify things for you.
The mileage is on the surface mounted chip (I think it's either an HC11 or HC12 chip) that's at the middle/right of the circuit board posted above. Reprogramming that is all that's needed to change the mileage (although it must be removed from the board first which is not easy without the right tools) A Tech II can not do that as far as I know. Tim |
(Post 1570331128)
I sure will give it a try and post the results, this Sunday I will do the install if there is no rain
Thanks for all the advise Tim |
.xel, the small board on the pic does not have the mileage?
(Post 1570333382)
I assure you it does. |
I have a 98, what does it cost to add the HUD and does it require a different windshield? Just curious as HUD appears to be the only option my car does not have, not even sure if it was available in the 98.
