C6 2006 keyless key 2 not option programmable
C6 2006 Keyless key 1 works find and is option programmable. Key 2 does opens and lock doors but is not recognized for DIC option programming. Any help?
Weak battery? Try putting it in the slot in the glovebox.
Also...be sure fob 1 is not anywhere near the car when you program fob 2. |
Thats because its not really #2, but rather #3 or #4. (3 and 4 can't be used for setting options).
If you only have 2 fobs, I'll bet that the original #2 was lost, and then replaced using the "short" learning method (making it fob #3). Cheers, Kent PS: you can erase all known fobs, and then reprogram your existing two fobs as #1 and #2. The process takes a while... you can find it in your owners manual, and it also has been documented here on the forum numerous times -- a quick search will find it. Unfortunately, you can't just program your existing #3 as number #2 -- you have to do a reset all. |
just tried inserting key in glove slot: Message on DIC is NO FOB PRESENT
As to Kent's suggestion, I bought car new, definately key 2. Additional info, key did work and displayed as #2 several weeks ago, The only thing that may have caused this is key was locked in car and used mechanical key to open hatch, alarm went off. does this mean anything? |
Originally Posted by myguyo
(Post 1570316324)
As to Kent's suggestion, I bought car new, definately key 2. Additional info, key did work and displayed as #2 several weeks ago, The only thing that may have caused this is key was locked in car and used mechanical key to open hatch, alarm went off. does this mean anything? Try changing the Fob's battery (as previously suggested by another member)... if that doesn't work, try disconnecting the car's battery for 10 min, reconnecting, and retrying the fob. If that doesn't work, a full keyless entry reset and fob relearn would be next on my list. If you're not comfortable with that, then a dealer visit might be in order. Cheers, Kent |
:iagree:
Just discovered another confusing fact. I took #1 key and put itin glove slot and got the same response. NO FOB. This key is good and works including programming. At this point I guess I will try your suggestions
(Post 1570318279)
Make sure you put it in the slot with the contacts facing the passenger door....:thumbs: |
Originally Posted by vetehead
(Post 1570318550)
(Post 1570318279)
If, as you state the reader does not recognize ANY FOBS then the reader could be defective. When you do a full reprogram the memory of ALL FOBs is wiped clean from the car and then the defective reader will not be able to relearn the FOBs. As someone else so eloquently put it this will result in you having in your possession a full scale non working die cast model of a C6 in your garage. :willy: Your only option then is having it towed to a dealer. I know as this happened to me. :sad: |
I'm not clear on the situation....if the DIC says "no Fob" then am I right that you cannot start the car now??:lurk:
Let me try and summarize the complete situation. Key 1 and 2 lock & unlock the doors/hatch and start the car. Key 1 is option programmable and is 100% functional. Key 2 in NOT option programmable therefore does not display a assigned number. If either key is placed in the glove socket, IN THE PROPER orientatiion, NO FOB is displayed and car does not start. Also new batteries were installed, no change.
I suspect two problems not 1, the glove reader and a unrecogized #2 key. |
(Post 1570335258)
I suspect two problems not 1, the glove reader and a unrecogized #2 key. Since the slot in the glovebox is not working, you need to take the car to the dealer and get them to fix that problem. While you're there, get them to do whatever they need to do to reprogram the fob that you think is #2 to really be fob #2. They should know how to do that. |
I would tentatively agree. FacadeC6 and I have been doing some thinking about the fob/slot system and we think that there are a certain number of people out there who have glovebox slots that do not work, but are not aware of it. I addressed a similar problem a while back having to do with the metal key...some have never used it and so do not know if it works or not. A bad time to find this out would be in the middle of the night in an airport parking lot. We will be putting out a thread on this soon.:thumbs:
For the dealer, the easy way out will be to plug in their Tech II machine and force the programming....but you want to make sure that your glovebox slot is working properly also, as you want the programming system to be functioning so that at some time in the future, you can program a new fob or whatever. You do not want to be dependent on a dealer to always do this. The car and the owner should be able to also, just as it says in the manual.:thumbs:
Thanks guys
Here hopefully is my final update.
Just got car back from dealer, glovebox reader now works but their fix didn't register with me. They said the car battery voltage was a little low. So they changed the battery which fixed the reader. I believe Kent was right and when they took out the battery to replace it the computers reset fixing the problem. If a little low battery voltage can cause this I pity cold weather owners. (LIKE ME) As for key #2, still doesn't allow option programming, I called them and we will try again on Monday. Assume they forgot or didn't understand the problem. I tried to program #2 as a unknown key, per the manual I opened the hatch then I turned the latch key 5 times in 5 second, I was then suppose to get a DIC mssage saying enter key #. The DIC doen't even come on. I give up this is like smashing your knuckles on a exhaust manifold, pure frustration |
(Post 1570351148)
When you go back to the dealer to get the fob reprogrammed, be sure they understand that it MUST be programmed as a no. 2 fob so it will have the memory options. Explain to them why it MUST be programmed as a no. 2 fob. |
I had this same problem... car wouldn't go into fob learn mode (no message on DIC after 5 key turns). Here's what works for me:
1) Put metal key in key cylinder back by license plate. Dont turn it yet, just leave it in there for now. 2) Put old, already-programmed-and-working fob in center console cupholder 3) Turn car 'on' using start button (you dont have to start it -- doesnt matter), then press start button again to turn car OFF. 4) Immediately run (yes, RUN) to the back of the car and turn the key five times. If you physically cant get back there very fast, have a helper ready to turn the key five times when you turn car off. This should trigger the "FOB" message on DIC. 5) Carry out the rest of the fob learning procedure as normal. This is the ONLY way my car will go into "fob learn mode". If I wait even 5-7 seconds between steps 3 and 4, my car will never go into fob learn mode, no matter how hard or fast I turn the key. Keep us posted on your results... Cheers, Kent |
Just purchased a 2006 C6 and hope I never have this problem. I think I might mess it up worse trying to get it fixed. GL
