Cabin Air Filter
Did a search but no answer to my question - does the passenger cabin air filter suck the air from below or top.
As dumb as I am, I took it out and am not 100% sure which way it goes back in - I would hate to accidentally reverse the direction. And no, I don't have a new one lying around that I could change it with. Thanks. |
from the top - - FYI the OEM one has an arrow showing UP . . .
Originally Posted by CQRT
(Post 1570365554)
Originally Posted by Mad*Max
(Post 1570365309)
Thans guys, I have put the dirty side up.
Been answered...http://forums.corvetteforum.com/1569872015-post107.html
Originally Posted by lander
(Post 1570366407)
I put in the Purolator for $11.00 and it has an arrow on it pointing up. I stuck my hand in there with fan on and the airflow is going up. It is not sucking it down as I thought it would be from windshield:lurk:.
Originally Posted by LS WON
(Post 1570372583)
(Post 1570366195)
(Post 1570372583)
/thread |
Originally Posted by ro2516
(Post 1570373109)
:rofl:
Originally Posted by Wilzer
(Post 1570365689)
Look at which side is dirty and that goes on top - replace with a Purolator C-25623 from advanced Auto for ~$11.48. It has a stiff material in the sides and won't wrinkle when you shove it back in. Watch out for the arrow, it may show airflow while the OEM shows direction, opposites - air flows from top down. Airflow should be down oem should be up. If you cleaned the OEM and replaced, you may have wrinkled the sides? $11.48 for a charcoal impregnated filter is cheap enough to replace often.[
(Post 1570373291)
The air flow is top to bottom, guaranteed.
/thread :iagree: :thumbs: :thumbs: |
(Post 1570373291)
Then why is the air current going up?:lurk:
Originally Posted by Monts
(Post 1570373372)
The Purolator does not have charcoal.
(Post 1570374216)
Yes it does have charcoal.
(Post 1570374265)
The specs on their website say nothing about charcoal so I called them this morning and was told that the filter for the Corvette does not have charcoal. Where are you getting the information that says otherwise?
(Post 1570374278)
Right off the filter I put in.:crazy:
