Insde door opening unit/rods
I removed the door panel to replaced the door opening unit . The rods that connect to it were loaded with grease . Everything the rods were connected to the same , loaded with hard dry grease , it was no wonder the door was hard to open . My question . . . do you used grease on areas where the rods connects ? Any kind of lube at all or not any. |
I used a spray white grease from Autozone
