Anyone upgrade to Z06 brakes on the rear only?
I've been looking at upgrading my brakes since it's time for new pads, mainly for the bling factor. I hate that little caliper on the back, and think the Z06 brakes look much better, mainly because the rear has a much larger caliper. Is anyone running Z51 brake rotors and calipers on the front, and Z06 rotors and calipers on the rear? Is this even something one should consider?
If not, then I may just do the upgrade all the way around. It looks like I can get a good deal on the following parts if I move now: OEM calipers and pads OEM rotors Brake lines Other than brake fluid, is there anything else that I will need? Also, I know that I will need new wheels. I'm probably going to just use spacers until some Z06 Spyders in 19x11 come out. |
Originally Posted by batmoble
(Post 1570596384)
If not, then I may just do the upgrade all the way around. It looks like I can get the parts for the following if I move now: OEM calipers and pads - $900 OEM rotors - $400 Brake lines - $100 Other than brake fluid, is there anything else that I will need? Also, I know that I will need new wheels. I'm probably going to just use spacers until some Z06 Spyders in 19x11 come out. In my opinion, go for the whole package. Easy to say when it isn't my money. :lol: |
Originally Posted by talon90
(Post 1570596416)
Putting just Z06 on the rear would cause one hell of a brake bias problem in my opinion. I don't think that I'd do that.
I have a Z51 and recently did the rear wide body only and installed the rear Z06 calipers, rotors and StopTech lines.
The brakes work just fine. Don't notice a difference in braking over the all Z51 brakes. |
Originally Posted by KarlK
(Post 1570597308)
(Post 1570597308)
Originally Posted by johnodrake
(Post 1570598262)
No reason they wouldn't, but as Paul said, you have a bias change. Would not be noticeable unless driven hard. Then you would notice more rear brake - bit looser under hard braking.
I will say however that ceramics are great for "no dusting" but do extend the stopping distance. |
(Post 1570598171)
Any pics?
(Post 1570598561)
I don't track the car but for daily and spirited driving, the car brakes and handles just fine. I took it out a couple weekends ago on its hardest uphill Dragon Tail like run and it felt the same to me. :cheers:
