Water Wetter does it help and how did you use it?
I read the bottle and the directions were to add to your normal coolant mixture to lower temps. Has anyone done this, how much did you add, and what effect did it have?
The whole bottle. Dependent on the car it may help it cool better. It reduces surface tension and helps the coolant make better contact with parts of the system. This makes for better heat transfer.
drain the radiator, add Water Wetter, refill fwith plain water.
Repeat but put antifreeze back in before Winter. If you just drain the radiator, you only get about 1/2 the coolant out, which gives you some benefit of WaterWetter but also keeps some of the benefits of anti-freeze. |
When you refill use distilled water
Originally Posted by davidfarmer
(Post 1570911601)
Water Wetter acts as a lube for the water pump as well.
I'm not sure that I trust Water Wetter's lubricating properties so I'm currently on 25% dexcool and one bottle of WW.
I haven't got the thing onto a track since doing this so I can't comment on the difference, but ECTs did seem a little lower in street driving. fwiw, this guy spent some time looking into the WW chemistry and came up with a thumbs-down: http://www.wizdforums.co.uk/showthread.php?t=2338 |
I believe in it. My car is a 1994 C4, 383 autocross car. We had two drivers at a poorly attended event, maybe 16 drivers so we were running pretty much non-stop and we didn't have time to shut the car off between runs. 94 degree day in FL. Highest temp was 182. Fans brought it back down to 172 almost immediately.
4 bottles of WW and the rest Prestone premix. |
I did back-to-back race tests years ago at the Savannah double national. I used Water Wetter on the 2d race. It made no difference. Save your money.
Chris
What was your mix prior to the WW? I've always used two bottles of WW and distilled water........no problems except when the thing throws a belt!!! |
Far too many people have tested it and showed results for anyone to doubt it. It works different car to car but it does work. I worked at a race school for a while and we ran water and WW, that's it. The cars had 13b rotaries in them which make lot's of heat. The water pumps almost NEVER died. They would outlast multiple motors.
I have been told that WW is nothing much more than soap but I'm not a chemist so whatever. |
I've used a similar product in my 67 GTO and saw no difference in temperatures. I used strictly water to the WW product, in the ratios recommended. One thing I noticed after about 4 months was a lot of corrosion in the neck/cap area of my Be Cool radiator. I started to wonder what the inside of the radiator was doing as well. I drained the stuff out and went back to a 50/50 mix of water and antifreeze. The car runs hot but doesn't overheat unless I really push it hard. The WW never brought the temps down, and the cool down took just as long. Sorry, not a believer of these products.
Thanks to everyone for the information.
Water Wetter does lube the water pump as does standard antifreeze.
Antifreeze will not keep a car as cool as distilled water. Tap water will leave residue in a cooling system. If a car is never exposed to freezing conditions then a combination of some sort of water pump lube and distilled water is best to keep the car as cool as possible. |
Originally Posted by CP Thunder
(Post 1570938306)
Chris
What was your mix prior to the WW? I've always used two bottles of WW and distilled water........no problems except when the thing throws a belt!!! The next year I dropped the mix level down to 10% antifreeze, used fresh distilled water and did a race. The very next day's race I added the water wetter and just as before, saw no difference in coolant temps. Waste your money if you want. |
Originally Posted by wtknght1
(Post 1570943293)
I tried it at Savannah one year by just adding it to the mix (probably 30% antifreeze) and didn't see any temp differences at all.
The next year I dropped the mix level down to 10% antifreeze, used fresh distilled water and did a race. The very next day's race I added the water wetter and just as before, saw no difference in coolant temps. Waste your money if you want. you run anti-freeze at the track? |
Originally Posted by ryan0
(Post 1570943479)
some tracks are like that........I know we HATE antifreeze at MAM........WORSE than oil!!!
(Post 1570943774)
no doubt.. i didn't think anyone who knew better still did this. |
(Post 1570943479)
